From an urn with numbers $1,...,n$ we draw $k < n$ numbers without replacement.
Let $X_i$ be the $i$-th draw. The random variable is their sum $X=\sum_{i=1}^kX_i$.
I have already calculated the expected value of the sum, which is
$$\Bbb{E}[X]=\sum_{i=1}^k\Bbb{E}[X_i]=k\frac{n+1}{2}$$ because each $\Bbb{E}[X_i]=\frac{1}{n}\sum_{i=1}^n i=\frac{n+1}{2}$.
Now the variance of the sum would be $$Var[X]=\Bbb{E}[X^2]-\Bbb{E}[X]^2$$
I have read that the variance of a sum is the sum of variances if the random variables are independent, it does not seem to be the case here, as previous draws determine future draws.
Is there an elegant way to determine the first summand of the variance?
Edit: I am trying it the ugly way.
$\Bbb{E}[X^2]=\Bbb{E}[(\sum_{i=1}^kX_i)^2]=\Bbb{E}[\sum_{i=1}^k \sum_{j=1}^k X_iX_j]=\sum_{i=1}^k \sum_{j=1}^k \Bbb{E}[X_iX_j]$
To know $\Bbb{E}[X_iX_j]$ we would have to know $\Bbb{P}(X_iX_j=k)$, meaning we would have to know the number of ways to write a number as the product of two factors $1\leq X_i, X_j \leq n$... I am pretty sure I am off the track here, as I do not see a way to do it for a general $n$.
Am I wrong to regard the $X_i$ instead of the $X$, which are independent, as two draws of $k$ balls would be independent? Then $\Bbb{E}[X^2]=\Bbb{E}[X]\Bbb{E}[X]$
