This system of congruences can be solved by inspection - without rote application of CRT. The first two equations are $\rm\, x \equiv -1\ (mod\ 2,3)\ $ so by CCRT or lcm they're equivalent to $\rm\ x\equiv -1\ (mod\ 6).\,$ To solve this and the remaining equation is easy because the moduli $\rm\ m=5,\, n=6\ $ are such that one has an obvious inverse modulo the other, i.e. $\rm\,6\equiv 1\ (mod\ 5)\,$ so $\rm\:6^{-1}\equiv 1^{-1}\ \equiv 1\ (mod\ 5)\:.\:$ Thus applying EasyCRT below with $\rm\,b = -1,\,n=6,\,m=5\,$ we obtain
$$\rm\ x\ \equiv\ b + n\ \bigg[\frac{a-b}{n}\ mod\ m\bigg]\ \equiv\ -1 + 6\ (a+1)\ \equiv\ 5+6a\ \ (mod\ 30)\qquad$$
Remark $ $ These special cases of CRT, where RHS is constant, and where one modulus has obvious inverse mod the other, are well worth knowing, since they arise frequently in practice, so they often go a long way towards shortening manual calculations. Below is the EasyCRT that we employed.
Theorem (Easy CRT) $\rm\ \ $ If $\rm\ m,\:n\:$ are coprime integers then $\rm\ n^{-1}\ $ exists $\rm\ (mod\ m)\ \ $ and
$$\rm \begin{align} &\rm x\equiv a\,\ (mod\ m)\\ &\rm x\equiv b\,\ (mod\ n)\end{align} \iff\ x\ \equiv\ b + n\ \bigg[\frac{a-b}{n}\ mod\ m\:\bigg]\ \ (mod\ m\:\!n)\qquad$$
Proof $\rm\ (\Leftarrow)\ \ \ mod\ n\!:\ x\equiv b + n\ (\cdots)\equiv b,\ $ and $\rm\ mod\ m\!:\ x\equiv b + (a-b)\ n/n \equiv a$
$\rm\ (\Rightarrow)\ \ $ The solution is unique $\rm\ (mod\ m\!\:n)\ $ since if $\rm\ x',\:x\ $ are solutions then $\rm\ x'\equiv x\ $ mod $\rm\:m,n\:$ therefore $\rm\ m,n\ |\ x'-x\ \Rightarrow\ m\!\:n\ |\ x'-x\ \ $ since $\rm\ \:m,n\:$ coprime $\rm\:\Rightarrow\ lcm(m,n) = m\:\!n.\ $ QED
