How to find necessary and sufficient conditions for the sum of two numbers to divide their product.
Thanks in advance.
Thanks in advance.
There's a solution of this problem in this post on codereview.stackexchange.com. Let me review it, hopefully correctly.
Assume $a, b$ not both zero. Let $d = \gcd(a,b) \ne 0$. Then $a = a' d, b = b' d$, and we have that $a + b = (a' + b') d$ divides $ab = a'b'd^2$, so $a' + b'$ divides $a'b'd$.
Since $a'$ and $b'$ are coprime, if $p$ is a prime divisor of $a'+ b'$, this must divide $d$. This is because $p$ divides $a'b'd$, so it must divide one of the factors. If $p$ divides $a'$, say, then since $p$ divides $a' + b'$, and then $b'$, against the assumption that $a', b'$ are coprime. Thus $a'+b'$ divides $d$.
So the recipe appears to be the following. Choose any coprime pair $a', b'$, and construct $$a = c (a'+b') a', \qquad b = c (a'+b') b',$$ for arbitrary $c$.
If, $\dfrac{ab}{a+b}=n$
Then,
$\dfrac{1}{a}+\dfrac{1}{b}=\dfrac{1}{n}$
I don't know if this is to be considered an answer or not.
Dividing $\rm\:(A\!+\!B)n = AB\:$ by $\rm\:d=(A,B)\:$ yields $\rm\: (\color{#C00}{a\!+\!b})n = d\color{#C00}{ab},\:$ for $\rm\,a,b = A/d,B/d$.
$\rm(a\!+\!b,b)\!=\!(a,b)\!=\!1\!=\!(a\!+\!b,a)\:$ so by Euclid $\rm\:(\color{#C00}{a\!+\!b,ab})\!=\!1\:$ so $\rm\:a\!+\!b\mid d,\,$ so $\rm\,(a\!+\!b)c = d.$
So $\rm\, A,B = da,db = (a\!+\!b)ca,(a\!+\!b)cb,\,$ and $\rm\:A\!+\!B = (a\!+\!b)^2c\mid (a\!+\!b)^2 c^2 ab = AB.$
A simple condition can be found that does not require using the GCD and yet allows you to determine all the solutions. But let me rephrase the problem:
Given any integer $x$, find all integers $y$ such that $x+y \mid xy$.
We know that $x+y \mid x(x+y)$ and so
$x+y \mid x(x+y) - xy = x^2$. The RHS does not depend on $y$ anymore.
Therefore, $y=d-x$ for all $d \mid x^2$
