I have a proof of this for a real valued function
https://www.encyclopediaofmath.org/index.php/Function_of_bounded_variation#Generalizations based on the Jordan decomposition into monotonic functions.
I am looking for a more general proof in the case of a function $f: I = [a, b] \subset \mathbb R \to X$ where $X$ is a complete normed vector space (or even more generally, a complete metric space $(X, d)$ in which case substitute $||f(s) - f(t)||$ by $d(f(s) - f(t))$ in what follows) .
My own attempt follows and I would appreciate feedback on this.
Definitions:
Let $f: I = [a, b] \subset \mathbb R \to X$ where $X$ is a normed vector space and $||.||$ its norm.
A partition of a $[a, b]$ is a finite set of points $P = \{p_0 = a < p_1 < p_2 ... < p_n = b\}$
$V(f, P):= \sum_{i=1}^n ||f(p_i) - f(p_{i-1}||$ is a real non-negative number being the variation of $f$ on the partition $P$ (of the interval $I$). Note that the variation is defined for any function and any partition.
$V(f):= sup\{V(f, P): P $ is a partition of I } is an extended real (i.e. can be $+\infty$) being the (total) variation of $f$ on the interval $I$.
If $V(f)$ is finite then $f$ is a function of bounded variation.
$f$ has a left limit at $x \in (a, b]$ if given $\epsilon > 0$ there is $w \in [a, x)$ such that for all $y, z \in (w, x)$ then $||f(y) - f(z)|| < \epsilon$. This is the Cauchy condition for the existence of this limit in a complete space. The right limit is similarly defined for $x \in [a, b)$.
Proof:
Assume that $f$ does not have a left limit at some point $x \in (a, b]$ and construct a sequence of partitions of $[a, x]$ of increasing (unbounded) variation. This shows that in such cases $f$ cannot be of bounded variation (on $[a, x]$ and therefore also on $[a, b]$). The case for not having a right limit is analogous, so it follows by contra-positive that if $f$ is of bounded variation these limits must exist.
Express the absence of a left limit by negation of the Cauchy definition.......
If $f$ has no left limit at $x \in (a, b]$ then there is some $\epsilon > 0$ where for all $w \in [a, x)$ there is some $y, z \in (w, x)$ with $||f(y) - f(z)|| \ge \epsilon$. Wlg assume $y < z$.
Firstly, this applies for $w = a$ and there is $a < y_1 < z_1 < x$ with $||f(y_1) - f(z_1)|| \ge \epsilon$. Now define the partition $P_1 = \{a, y_1, z_1, x\}$ and it follows that $V(f, P_1) \ge \epsilon$.
As a second iteration, the condition applies for $w = z_1$ so there is $z_1 < y_2 < z_2 < x$ with $||f(y_2) - f(z_2)|| \ge \epsilon$. Define the partition $P_2$ by adding $y_2, z_2$ to $P_1$ (in sequence) $ = \{a, y_1, z_1, y_2, z_2, x\}$ and it follows that $V(f, P_2) \ge 2\epsilon$.
Then one can continue and define a sequence of partitions of $[a, x]$ $P_1, P_2, .....$ and for $P_n$ we have $V(f, P_n) \ge n.\epsilon$ so $sup\{V(f, P): P $ is a partition of $[a, x]\} = \infty$, I.e. $f $ is not of bounded variation on $[a, x]$.
