Focusing only on this particular line, we bring the $e^{-n}$ inside and write
$$k \ln(n) - \ln(k!) - n \\= n \ln(n) - n - \ln(n!) + (k-n) \ln(n) + \ln(n!) - \ln(k!).$$
The first three terms by Stirling's approximation are $\ln((2\pi n)^{-1/2})+o(1)$.
To handle $\ln(n!)-\ln(k!)$ we might hope to replace it by $\ln(\Gamma(n+1)) - \ln(\Gamma(k+1))$ where $k$ is now thought of as a continuous quantity, and then obtain the Taylor approximation
$$\ln(n!)-\ln(k!) \approx (n-k) \psi^{(0)}(n+1) - \frac{1}{2} (n-k)^2 \psi^{(1)}(n+1)$$
where $\psi^{(j)}$ are polygamma functions. Now we need to know some asymptotics for the $\psi^{(j)}$; one might hope that these correspond to term-by-term differentiation of Stirling's approximation, but this doesn't come for free from any general theorem.
Anyway, it turns out that the results needed here do work out the way that you would expect by differentiating the Stirling approximation. Specifically, $\psi^{(0)}(n+1)=\ln(n)+O(1/n)$ and $\psi^{(1)}(n+1)=1/n+o(1/n)$ as $n \to \infty$. Thus the term $(n-k)(\psi^{(0)}(n+1)-\ln(n))$ becomes significant only when $|n-k|=\Omega(n)$. Meanwhile, $\psi^{(1)}(n+1)(n-k)^2$ becomes significant when $|n-k|=\Omega(n^{1/2})$. The end result is that by the time the linear term is significant, the quadratic term has already made the overall exponential vanishingly small anyway. In this way we obtain the approximation
$$k\ln(n)-\ln(k!)-n \approx \ln((2\pi n)^{-1/2}) - \frac{(n-k)^2}{2n}.$$
You can recognize the first term as the logarithm of the normalization constant of a Gaussian density and the second term as the logarithm of the exponential part of the Gaussian density.
Formalizing this properly really requires you to first justify passing to an integral in the first place so that you can properly apply Watson's lemma in order to justify using derivatives to begin with. I consider that step to be beyond the scope of this question.
In general I think ironing out Felix's approach is quite a bit more difficult than using the explicit relationship between the partial exponential sum and the incomplete Gamma function, as discussed in other answers to that question.
