So I was assigned this homework problem: $$\ {s \choose s} + {s+1 \choose s} +...+ {n \choose s} = {n+1 \choose s+1}$$ for all s and all $n \geq s$ I've tried to email both my professor and my TA and their explanations seem contradictory. My professor responded saying the statement I need to prove is "The formula is correct for $0 \leq s \leq n$." Whereas my TA told me I need to use induction on both variables and I'm not sure how to do that. Any help is appreciated!
Asked
Active
Viewed 57 times
It should indeed be proven for all values of $s$ and $n$ such that $0\leq s\leq n$. Since you are tasked with showing it for all values of $s$ and $n$ satisfying this, using double-induction is standard. – JMoravitz Apr 12 '19 at 23:19
Thank you for linking that proof! I'll try to work my way through that proof now and see if I can apply it to mine. – EpicViiper Apr 12 '19 at 23:32
Use induction on $n$. Fix $s \leq n$. If the equation holds then it holds with $n$ cha nged to $n+1$ because of the following identity: $\binom {n+1} {s+1} +\binom {n+1} s=\binom {n+2} {s+1}$. You can verify this identity by writing the binomial coefficients in terms of factorials. To complete the proof you only have to verify the equation with $n$ changed to $n+1$ and $s=n+1$. But this just reduces to $1=1$!
Kavi Rama Murthy
- 311,013
So when I do my base case, do I set n and s to be equal to 1? Or just s? – EpicViiper Apr 12 '19 at 23:35
When $n=1$ you have to consider the cases $s=0$ as well as $s=1$. The first leads to $1+1=2$ and the second one leads to $1=1$. – Kavi Rama Murthy Apr 12 '19 at 23:37
Oh okay that makes sense. So then in my inductive step, I would assume that the formula is true for some s such that $s \leq n$. I want to show that it works for any $s \leq n+1$ then so would I just do the algebra in the equation? I.e. the last term on the LHS is ${n+1 \choose s}$ and the right hand side is ${n+2 \choose s+1}$ – EpicViiper Apr 12 '19 at 23:44
Yes. You have to separate the cases $s \leq n$ and $s=n+1$ as I have done. – Kavi Rama Murthy Apr 12 '19 at 23:46
