Easy fact: If an ideal is a prime power, then its radical is prime.
I'd like to give a counterexample to the converse. A good candidate is $I=(y^2,xy) \subseteq K[x,y]$, since this post shows that it has prime radical: Is it true that an ideal is primary iff its radical is prime?
How do I show that $I$ is not a prime power? I am not sure where to begin; I've done the following: suppose $I=p^n$ for some prime ideal $p$. I try localising at $p$: $P_p^n=(y^2,xy)_p=(y)_p^2+(x)_p(y)_p$. What next?
Aside: is there an easier counterexample?
SSF
  • 905
    Try $I = (x^2, y^3)$. If it's a prime power it must be a power of its radical, namely $(x, y)$. So just show that it isn't. – Qiaochu Yuan Apr 03 '19 at 00:17
  • I see. Just to see if I've got this right: since $I=p^n$, take radicals to get that $rad(I)=rad(p^n)=p$, so $I$ is a power of its radical. And this also works using my choice of $I=(y^2,xy)$, whose radical is $(y)$, right? In this case it's immediately clear that $I=(y^2,xy)$ is not a power of its radical $(y)$. – SSF Apr 03 '19 at 03:06
    Yes, that’s right. – Qiaochu Yuan Apr 03 '19 at 03:17
