A famous question from children's textbook on LCM (least common multiple) is: A bookstore named X Y Z has its named flashed on a neon light board. All the three letters flash for a duration of $1$ second before being put off. $X$ flashes after every $2 \frac{1}{2}$ sec, $Y$ flashes after every $4 \frac{1}{4}$ seconds and $Z$ flashes after every $5 \frac{1}{8}$ seconds. When will the full name of the bookstore be readable?
Now since this questions has been pigeonholed to the category of LCM in general textbooks a simple solution follows which gives $\text{LCM}[5 \frac{1}{8}+1,2 \frac{1}{2}+1,4 \frac{1}{4}+1]$ as the answer. I would be happy with the answer had the question been asking "when will all the letters light together" but the questions asks when they will all be lighting simultaneously. So, why are we not looking at situations in which one of them say $X$ starts lighting and in the $1$ second period of its being live, the other two start lighting. Is that too obvious that such a case won't exist[If it is please elaborate on how that can be seen] or is it just that since the question has been cloistered to one category, we don't pay much heed to it.
