Given a manifold and its metric tensor, how can I compute the distance between two points on the manifold?
What are the high level steps?
Edit: In particular, suppose the manifold is an open unit ball in $R^d$ $$B = \{ x \in \mathbb R ^d: |x| < 1 \},$$ and the metric tensor is $$\frac{2}{(1-\|x\|^2)^2} g_E$$ where $x \in B$ and $g_E$ is the Euclidean metric tensor. How should one compute the distance between two points on the the manifold?
user25004
  • 3,586
  • 33
  • 61
If you have a curve on the manifold (say two-dimensional) $u_i=u_i(t)$, between $t=t_1$ and $t=t_2$, and your metric tensor is $g_{ij}$ (covariant components), then the length of the curve is given by $$ \int\limits_{t_1}^{t_2}\sqrt{g_{ij}(u(t))\partial_tu^i\partial_tu^j}\,dt. $$ If you choose your curve to be a geodesic, then you get the distance.
GReyes
  • 16,446
  • So the geodesics should be derived first? – user25004 Mar 22 '19 at 13:17
    @user25004 : as Travis pointed out, a metric can be induced by considering the infimum of the length of the paths connectig A and B, that is, the length of the curve that minimize lenght. This curve is a geodesic. So yes, you have to derive the geodesic first –  Mar 22 '19 at 14:22
  • Yes you have to solve the second order ODEs for them. Given your metric you find the Christoffel symbols etc. Your concrete metric differs by a factor from the Euclidean one so many computations will be simple. – GReyes Mar 22 '19 at 19:06
