Programs like Mathematica, Maple, Maxima and many others can compute integrals, differentiate mathematical expressions or do all other sorts of cool stuff. My question is what kind of mathematics do they use to do what they do? To make my question less broad, let's focus on finding closed-form solutions to integration problems.
I think differential Galois theory might be useful, for example. If a CAS wants to solve an integral, it should better check that the integral is expressible in terms of the functions it already knows first. Right? If so, how can differential Galois theory be applied in designing a computer program?
I think a CAS should have a long list of elementary and non-elementary functions with their derivatives and anti-derivates. Then when an integration problem is given, it might first try to apply integration by parts by checking different choices for $u$ and $dv$. Since there seems to be a finite number of possible choices and it can check all of them in a matter of miliseconds, it seems that a brute-force approach using integration by parts equipped with a dictionary of already known functions can solve many problems quickly. Is that how things are done? Or are there cleverer methods that consume less resources and time than simple brute force?
If anyone has experience working at a company developing this kind of tools, please do share your experience (if you wish, of course). Also, if someone knows about a book or resources on how to develop a CAS, please share them. Thanks in advance.
stressed out
  • 8,130
  • There are algorithms. Start by searching for Risch, and for "integration in finite terms". The book at https://www.springer.com/gp/book/9783540102908 might get you started. – Gerry Myerson Mar 08 '19 at 11:53
  • @GerryMyerson Thank you. Is "integration in finite terms" the title of a book or something? – stressed out Mar 08 '19 at 11:58
  • It's a phrase.. – Gerry Myerson Mar 08 '19 at 12:12
    See also the answer to https://math.stackexchange.com/questions/21305/algorithms-for-symbolic-manipulation – Gerry Myerson Mar 08 '19 at 12:15
    Indefinite integration algorithms use differential algebra. No Galois theory is used - that plays a nontrivial role only for higher-order differential equations. Nor does it employ integration by parts or table lookup. For a brief overview in the simpler transendental (non-algebraic function) case see this answer. – Bill Dubuque Mar 08 '19 at 19:56
  • That said, for special functions that are not included in (extensions of) the Risch decision procedure, they do often use heuristics and table lookup, etc. – Bill Dubuque Mar 08 '19 at 20:00
