Yes, Euclid's Lemma is true in gcd domains (domains where any two nonzero elements have a gcd), but the lemma may fail in domains where some gcds fail to exist (e.g. below). Below is some general discussion on this and related matters in an arbitrary integral domain.
Lemma $\rm\ \ (a,b)\ =\ (ac,bc)/c\quad$ if $\rm\ (ac,bc)\ $ exists $\rm\quad$ (GCD distributive law )
Proof $\rm\quad d\ |\ a,b\ \iff\ dc\ |\ ac,bc\ \iff\ dc\ |\ (ac,bc)\ \iff\ d|(ac,bc)/c$
But generally $\rm\ (ac,bc)\ $ need not exist, as is most insightfully viewed as failure of
Euclid's Lemma $\rm\quad a\ |\ bc\ $ and $\rm\ (a,b)=1\ \Rightarrow\ a\ |\ c\quad$ if $\rm\ (ac,bc)\ $ exists.
Proof $\ \ $ If $\rm\ (ac,bc)\ $ exists then $\rm\ a\ |\ ac,bc\ \Rightarrow\ a\ |\ (ac,bc) = (a,b)\:c = c\ $ by the Lemma.
Therefore if $\rm\: a,b,c\: $ fail to satisfy the Euclid Lemma $\Rightarrow\:$,
namely if $\rm\ a\ |\ bc\ $ and $\rm\ (a,b) = 1\ $ but $\rm\ a\nmid c\:$, then one immediately deduces that the gcd $\rm\ (ac,bc)\ $ fails to exist.$\:$ For the special case that $\rm\:a\:$ is an atom (i.e. irreducible), the implication reduces to: atom $\Rightarrow$ prime. So it suffices to find a nonprime atom
in order to exhibit a pair of elements whose gcd fails to exist. This task is a bit simpler, e.g. for $\rm\ \omega = 1 + \sqrt{-3}\ \in\ \mathbb Z[\sqrt{-3}]\ $ we have that the atom $\rm\: 2\ |\ \omega'\: \omega = 4\:,\:$ but $\rm\ 2\nmid \omega',\:\omega\:,\:$ so $\rm\:2\:$ is not prime. Therefore the gcd $\rm\: (2\:\omega,\ \omega'\:\omega)\ =\ (2+2\sqrt{-3},\:4)\ $ fails to exist in $\rm\ \mathbb Z[\sqrt{-3}]\:$.
Note that if the gcd $\rm\: (ac,bc)\ $ fails to exist then this implies that the ideal $\rm\ (ac,bc)\ $ is not principal. Therefore we've constructively deduced that the failure of Euclid's lemma immediately yields both a nonexistent gcd and a nonprincipal ideal.
That the $\Rightarrow$ in Euclid's lemma implies that Atoms are Prime $\rm(:= AP)$ is denoted $\rm\ D\ \Rightarrow AP\ $ in the list of domains closely related to GCD domains in this post. There you will find links to further literature on domains closely related to GCD domains. See especially the referenced comprehensive survey by D.D. Anderson: GCD domains, Gauss' lemma, and contents of polynomials, 2000.
See also this post for the general universal definitions of $\rm GCD,\: LCM$ and for further remarks on how such $\iff$ definitions enable slick proofs, and see here for another simple example of such.
