16
Question (asking on behalf of my friend who studies abstract algebra):
Is there a group $G$ and subgroup $H$, such that there exists $g\in G$ with $gHg^{-1} \subset H$ and $|H:gHg^{-1}|$ is infinite? ( I incline to think this is true.)
For such an example to exist, $H$ (and hence $G$) must be infinite and a non-normal subgroup of $G$. At first, it seems easy. However, I really don't know many types of infinite nonabelian groups (perhaps only the general linear group ${GL}_n(F)$ and the group of bijections). Thanks for your slightest effort.
YuiTo Cheng
  • 4,705
Let $\,G\,$ be the free group generated by $\,g,x_1,x_2,\dots\,$ modded by the equations $\,gx_ng^{-1} = x_{n+1}\,$ for all $n>0.$ Let $\,H\,$ be the subgroup generated by all the $\,x_n.\,$ The index of $\,gHg^{-1}\,$ in $\,H\,$ is infinite because $\,x_1\,$ has infinite order. Note that there are more concrete ways to represent the groups and specializations where all the $\,x_n\,$ commute with each other but not with $\,g.\,$
Somos
  • 35,251
  • 30
  • 76
Yes.
For example, take $G$ to be the HNN-extension* $$\langle a, b, t\mid t^{-1}at=[a, b], t^{-1}bt=b\rangle$$ and $H=\langle a, b\rangle$. By the theory of HNN-extensions, $H$ embeds into $G$ in the natural way. Clearly $t^{-1}Ht\leq H$. To see that $|H:t^{-1}Ht|$, note that the presentation $\langle a, b\mid [a, b], b\rangle$ defines an infinite group. Hence the smallest normal subgroup of $H$ containing $[a, b]$ and $b$ has infinite index in $H$; hence the smallest subgroup of $H$ containing $[a, b]$ and $b$, which is $\langle [a, b], b\rangle$, has infinite index in $H$. As $t^{-1}Ht=\langle [a, b], b\rangle$, the result follows.
*For background on HNN-extensions see Wikipedia or the book Combinatorial group theory by Lyndon and Schupp.
user1729
  • 31,015
$\newcommand{\bZ}{\mathbf Z}\newcommand{\bN}{\mathbf N}$ Let $\overline{H}$ be the group of functions $\bZ\to \bZ$ (with pointwise addition), while $H$ is the group of functions which vanish on negative integers.
Now, consider the semidirect product $G:=\overline{H}\rtimes \bZ$, where $\bZ$ acts on $\overline{H}$ by shifting to the right, so $(1\cdot f)(k)=f(k+1)$. Then if you take $g=(0,1)\in G$, then $gHg^{-1}\unlhd H$ (it is just the set of functions $\bZ\to \bZ$ which vanish on non-positive integers) and $H/gHg^{-1}\cong \bZ$.
If you replace functions $\bZ\to \bZ$ with functions into any other group $K$, then you will have $H/gHg^{-1}\cong K$.
Note that this construction is the (unrestricted) wreath product of $\bZ$ with itself.
tomasz
  • 35,474
    "Wreath product"? That sounds quite technical...Upvote it anyway. – YuiTo Cheng Feb 21 '19 at 12:10
  • @YuiToCheng: It is not really. The first two paragraphs have a complete description, the wreath product is just a technical term. If you understand semidirect products, it should be clear. – tomasz Feb 21 '19 at 12:11
    Wreath product is one of the oldest group constructions, and occurs at many places. – YCor Feb 21 '19 at 13:20
This is a very good question, and the answer is yes.
An example is given by $G= \mathfrak{S}\mathbb{Z}$, the group of permutations of $\mathbb{Z}$, and $H$ is the subgroup of permutations that fix $\mathbb{Z}_{-}$ pointwise (so the image of $\mathfrak{S}\mathbb{N}$ under the obvious morphism)
Now for $g\in G$, $gHg^{-1}$ is the group of permutations that fix $g\mathbb{Z}_{-}$ pointwise, so whenever $\mathbb{Z}_{-}\subset g\mathbb{Z}_{-}$, we have $gHg^{-1}\subset H$.
In particular if $g\mathbb{Z}_{-}\setminus\mathbb{Z}_{-}$ is infinite, then $gHg^{-1}$ has infinite index in $H$, and of course this can happen if you choose $g$ well enough.
Maxime Ramzi
  • 43,598
  • 29
  • 104
