Would you please help me in how to show that:
If $T : X \to Y$ is a continuous linear map between two locally convex spaces and $K \subset X$ is compact convex, then:
  1. The continuous image of compact convex space is a compact convex.
  2. If $y$ ia an extreme point of $T(K)$, then $\exists$ $x \in X$ an extreme in $K$ such that $Tx =y$
Thank you, Saba
Rasmus
  • 18,404
saba
  • 153
The first point is obvious:
  1. Compactness is preserved by continuous maps so $T(K)$ is compact.
  2. Convexity is preserved by linear maps, so $T(K)$ is convex.
As for the second point, we need to know a bit more, I think.
First of all, I assume that your definition of locally convex includes Hausdorff, otherwise there are silly counterexamples (see right at the end of the answer).
The idea is the following: If $y \in T(K)$ is extremal then $F = \{x \in K\,:\,T(x) = y\}$ is a face of $K$ and by the Kreĭn-Mil'mans theorem every face contains an extremal point. If you know what a face is and just want to see see why $F$ is a face, you can ignore the next section and jump right to the claim afterwards.
Also, I overlooked the homework tag, so maybe I shouldn't have given all away below, stop reading now if you want to think for yourself.
Let me elaborate on this:
Recall that a face $F$ of a convex set $K$ is a non-empty and closed subset of $K$ with the following property: If $x,y \in K$ are any points for which there is $0 \lt \alpha \lt 1$ such that $(1-\alpha)x + \alpha y \in F$ then we must have $x,y \in F$ already. (Think of the faces of a cube, for example).
Let me sketch the proof of Kreĭn-Mil'man's theorem which states:
If $K$ is a compact convex set in a locally convex space, then it is the closed convex hulls of its extremal points.
Proof:
  1. For $x \in K$ the set $\{x\}$ is a face if and only if $x$ is extremal.
  2. If $\phi: X \to \mathbb{R}$ is a continuous linear functional and $F \subset K$ is a face, then $\{x \in F\,:\,\phi(x) \text{ is minimal}\}$ is a face again.
  3. Order the faces of $K$ by reverse inclusion. The intersection of a chain of faces is a face, thus every face contains a minimal face by Zorn's lemma.
  4. Combine 2. and Hahn-Banach to see that a minimal face cannot contain more than one point.
Taking 3. and 4. together we see that we have proved what we need for solving the exercise.
Every face of a compact convex set contains an extremal point.
Since it would be a pity to stop here, let me finish the argument for Kreĭn-Mil'man:
Since $K$ is a face of itself, there is at least one extremal point. If the closed convex hull $C$ of the extremal points were not all of $K$ then there were a point $z$ and a continuous linar functional $\phi$ such that $\phi(z) \lt \phi(c)$ for all $c \in C$. But by applying 2. to $\phi$ we find a face disjoint from all extremal points, a contradiction.
Claim: If $y \in T(K)$ is extremal, then $F = \{x \in K\,:\,T(x) = y\}$ is a face.
In particular, $F$ contains an extremal point by what I just said.
Proof of the claim: Obviously, $F$ is closed and non-empty. If $F$ were not a face, there would be $x_0,x_1 \in K \smallsetminus F$ and $0 \lt \alpha \lt 1$ such that $(1-\alpha)x_{0} + \alpha x_1 \in F$, so $(1-\alpha) T(x_0) + \alpha T(x_1) = y$, but $T(x_{0}) \neq y \neq T(x_1)$, so $y$ is not extremal, a contradiction.
To see that we need to assume at least that $X$ is Hausdorff, let $X = \mathbb{R}^2$ with the semi-norm $|(x,y)| = |x|$ and let $Y = \mathbb{R}$ with the usual topology. Let $T: X \to \mathbb{R}$ be projection on the first coordinate, $T(x,y) = x$. This map is continuous and obviously the $y$-axis $K$ in $X$ is compact and convex and contains no extremal point. However, $T(K) = \{0\}$ and the point $\{0\}$ is extremal. By construction there is no extremal point in $K$ contradicting the exercise.
t.b.
  • 78,116
-1
I think you will find this easier if you recall that "convex" can be defined in terms of inequalities and that the linear map will preserve those features.
Carl Brannen
  • 2,199
  • could you please explain more? I thought that I can prove that as the following T: K->T(K) is onto + continuous then I can prove T(K) is compact and from continuity and linearity I can show that T(K) is convex... is that true or not? – saba Apr 05 '11 at 23:14
  • Let $a,b$ be two points in $K$. By convexity, for any $0<\alpha<1$, the point $\alpha a+(1-\alpha)b$ is in $K$. Now use linearity to relate $T(\alpha a+(1-\alpha)b)$ to $T(a)$ and $T(b)$. For compact, my instinct is to think about "every sequence has a convergent subsequence". – Carl Brannen Apr 06 '11 at 00:08
