Let $f$ be a complex-valued, measurable function defined on $\mathbb R$ with $f(x)=f(x+2\pi)$
I want to show $$\int_{[0,2\pi]}f d\lambda=\int_{[\alpha,\alpha+2\pi]}f d\lambda $$
$(\alpha \in \mathbb R)$
My original attempt was to write $\int_{[\alpha,\alpha+2\pi]}f d\lambda -\int_{[0,2\pi]}f d\lambda=\int_{\alpha}^{\alpha+2\pi}f(x)dx-\int_{0}^{2\pi}f(x)dx=F(\alpha+2\pi)-F(2\pi)-(F(\alpha)-F(0))=\int_{2\pi}^{\alpha+2\pi}f(x)dx-\int_{0}^{\alpha}f(x)dx=0$
But I think I can't simply write is a Riemann Integral.
How can I show $$\int_{[0,2\pi]}f d\lambda=\int_{[\alpha,\alpha+2\pi]}f d\lambda $$ instead?
Edit: This proof assumes that $\alpha<2\pi$. But since $f$ is $2\pi$ periodic the function $f$ on $[\alpha,2\pi+\alpha]$ behaves the same as $f$ on $[\alpha-2\pi,\alpha]$ and we can keep removing $2\pi$ until $\alpha-2m\pi<2\pi$, then denote $\beta=\alpha-2m\pi$ and argue as below with $\beta$ instead of $\alpha$:
We can write $[\alpha,\alpha+2\pi] = [\alpha,2\pi]\cup [2\pi,2\pi+\alpha]$. Since the union is disjoint (up to one element) we have
$$\int_\alpha^{\alpha+2\pi} f(x)dx = \int_\alpha^{2\pi} f(x)dx+\int_{2\pi}^{2\pi+\alpha} f(x)dx$$
By assumption $f(x)=f(x+2\pi)$ and so by changing variables the second integral becomes
$$\int_{2\pi}^{2\pi+\alpha} f(x)dx = \int_0^\alpha f(x+2\pi)dx = \int_0^\alpha f(x)dx$$
Insert to the first equality we have
$$\int_\alpha^{\alpha+2\pi} f(x)dx = \int_\alpha^{2\pi} f(x)dx+\int_{0}^{\alpha} f(x)dx = \int_0^{2\pi}f(x)dx$$
Yanko
  • 13,758
    What if $\alpha>2\pi$? How do you make sense of the interval $[\alpha,2\pi]$? –  Jan 12 '19 at 16:37
    This would work if, instead of your "$2\pi$", you used the (unique) integer multiple of $2\pi$ between $\alpha$ and $\alpha+2\pi$. – paul garrett Jan 12 '19 at 16:40
  • @user587192 If $\alpha>2\pi$ then move the entire interval by $2\pi$ as many times as needed. – Yanko Jan 12 '19 at 16:54
