I was thinking of a mathematical puzzle with binary representation of numbers, but could not find a convincing answer myself.
Here is the puzzle: Say for some number N, I want to find the sum of the set bits of every number from 1 to N.
For example, for 5 The answer would be: 7 by the following procedure
1 - 1 set bit
2 - 1 set bit
3 - 2 set bits
4 - 1 set bit
5 - 2 set bits
So answer is 1 + 1 + 2 + 1 + 2 = 7
I found that it's easy to just go one by one and add, like I did. I also found that for a number having x bits, they form the pascal triangle with set ones, if number of occurances are counted with same number of set bits, irrespective of value. For example,
when x = 1, we have {1} - 1 set bit occurs once, hence 1.
when x = 2, we have {10, 11} - 1 set bit occurs once, 2 set bits occurs once, hence 1 1
when x = 3, we have {100, 101, 110, 111} - 1 set bit occurs once, 2 set bits occur twice, and 3 set bits occur once, hence 1 2 1
This series is continued. However, summing these up will give me a range, inside of which the answer lies. (Example ans is in [8, 15])
My first solution is the naive approach. Second one is a little mathematical, but not very fruitful.
I was wondering if we could derive a formula any N?
