Consider an extension of fields $K/F$ and $\alpha, \beta \in K$. If $\alpha$, $\beta$ are algebraically independent, is it true that the minimal polynomial of $\alpha$ (resp. $\beta$) on $K(\beta)$ (resp. $K(\alpha)$) are the same as the minimal polynomial of $\alpha$ (resp. $\beta$) on K? How could I prove this?
roi_saumon
  • 4,196
    Yeah. The minimal polynomials are defined over $K$. Algebraic independence means that there is no nontrivial relation between the two elements. – Wuestenfux Jan 02 '19 at 18:34
I'm afraid my answer here becomes a tad on the discursive side at some points, venturing into a few regions which are not, shall we say, exactly on the main line. I'll try to point the places where I stray from the "straight and narrow" path in what follows.
Let
$m_\alpha(x), m_\beta(x) \in F[x] \tag 1$
be the respective minimal polynomials of $\alpha$ and $\beta$ over $F$. The fact that $m_\alpha(x)$ and $m_\beta(x)$ are (tacitly) assumed to exist implies that $\alpha$ and $\beta$ are each algebraic over $F$; thus
$[F(\alpha):F], [F(\beta):F] < \infty; \tag 2$
furthermore, $m_\alpha(x)$ and $m_\beta(x)$ are each irreducible over $F$, as is well-known.
So far, so good. Now the next few lines are not absolutely essential to our main point, but nevertheless:
We observe that
$\alpha \notin F(\beta) \tag 3$
and
$\beta \notin F(\alpha), \tag 4$
since otherwise, for example
$\alpha = \displaystyle \sum_0^{[F(\beta):F]} a_i \beta_i, \; a_i \in F; \tag 5$
that is, $\alpha$ and $\beta$ together satisfy the bivariate polynomial
$p(x, y) = x - \displaystyle \sum_0^{[F(\beta):F]} a_i y^i \in F[x, y], \tag 6$
that is,
$p(\alpha, \beta) = 0 \tag 7$
which is just (5) written out in the form
$\alpha - \displaystyle \sum_0^m a_i \beta^i, \; a_i \in F = 0; \tag 8$
this contradicts the algebraic indendence of $\alpha$, $\beta$; thus (3), and similarly (4), bind. These facts are engaging in their own right, but not central to our major aims.
Back to the main line:
Now since
$F[x] \subset F(\beta)[x], \tag 9$
it follows that
$m_\alpha(x) \in F(\beta)[x]; \tag{10}$
thus if
$t_\alpha(x) \in F(\beta)[x] \tag{11}$
is the minimal polynomial of $\alpha$ over $F(\beta)$, it follows that
$t_\alpha(x) \mid m_\alpha(x) \tag{12}$
in $F(\beta)[x]$; hence we have some
$q_\alpha(x) \in F(\beta)[x] \tag{13}$
with
$m_\alpha(x) = t_\alpha(x) q_\alpha(x), \tag{14}$
which of course implies
$\deg t_\alpha(x) \le \deg m_\alpha(x); \tag{15}$
we obviously also have
$t_\alpha(\alpha) = 0. \tag{16}$
Now suppose
$t_\alpha(x) \ne m_\alpha(x); \tag{17}$
I claim we may thus infer that
$t_\alpha(x) \notin F[x]; \tag{18}$
for if this did not bind, (15)-(16) together contradict the uniqueness of $m_\alpha(x)$ as the minimal polynomial of $\alpha$ over $F$. Thus
$t_\alpha(x) \in F(\beta)[x] \setminus F[x]; \tag{19}$
which implies that some coefficient of
$t_\alpha(x) = \displaystyle \sum_0^{\deg t_\alpha(x)} t_j x^j \tag{20}$
must itself lie in $F(\beta) \setminus F$; but by virtue of (2), such $t_j$ may be expressed in the form
$t_j = \displaystyle \sum_0^{m_j} t_{jk} \beta^k, \; t_{jk} \in F, \; m_j > 0; \tag{21}$
then we may write
$t_\alpha(x) = \displaystyle \sum_0^{\deg t_\alpha(x)} \left (\sum_0^{m_j} t_{jk} \beta^k \right) x^j, \tag{22}$
where at least one of the $m_j > 0$, whence
$0 = t_\alpha(\alpha) = \displaystyle \sum_0^{\deg t_\alpha(x)} \left (\sum_0^{m_j} t_{jk} \beta^k \right ) \alpha^j \tag{23}$
expresses an algebraic dependence 'twixt $\alpha$ and $\beta$; that is, setting
$\phi(x, y) = \displaystyle \sum_0^{\deg t_\alpha(x)} \left (\sum_0^{m_j} t_{jk} y^k \right ) x^j \in F[x, y], \tag{24}$
we have
$\phi(\alpha, \beta) = 0. \tag{25}$
We conclude that
$t_\alpha(x) = m_\alpha(x). \tag{26}$
Interchanging the roles of $\alpha$ and $\beta$ in the above shows that the minimal polynomial $m_\beta(x)$ of $\beta$ over $F$ is the same as $t_\beta(x)$, the minimal polynomial of $\beta$ over $F(\alpha)$. And we are done.
Robert Lewis
  • 71,180
