Let $M$ be a non-zero finitely generated faithful module over a commutative ring with unity $R$. If $m,n$ are positive integers such that there exists an injective module homomorphism from $M^m$ to $M^n$, then does that imply $m \le n$ ?
user521337
  • 3,705
  • Faithfulness is irrelevant since you can always just mod out the annihilator. Perhaps you mean to instead assume $M$ is nonzero? – Eric Wofsey Jan 02 '19 at 06:11
[The following argument is adapted from this argument by Georges Elencwajg for the case $M=R$.]
Let us first reduce to the case that $R$ is Noetherian. Picking a finite set $G$ of generators for $M$, we can represent our map $f:M^m\to M^n$ with a matrix of elements of $R$. Let $S\subseteq R$ be the subring generated by the entries of this matrix. Let $N$ be the $S$-submodule of $M$ generated by $G$. Then $f$ restricts to an $S$-module homomorphism $N^m\to N^n$. Since $M$ is nonzero, so is $N$, and since $f$ is injective, so is $g$. Since the ring $S$ is finitely generated, it is Noetherian. So, we may replace $R$ with $S$, $M$ with $N$, and $f$ with $g$ and thus assume $R$ is Noetherian.
So from now on we assume $R$ is Noetherian. I now claim that if $P\subset R$ is any prime ideal, then $M_P$ is nonzero. Indeed, this follows from the fact that $M$ is finitely generated and faithful. Letting $x_1,\dots,x_k$ generate $M$, we have $\operatorname{Ann}(x_1)\dots\operatorname{Ann}(x_n)\subseteq \operatorname{Ann}(M)=0\subseteq P$, and so $\operatorname{Ann}(x_i)\subseteq P$ for some $i$ since $P$ is prime. That means that the image of $x_i$ in $M_P$ is nonzero, so $M_P$ is nonzero.
In particular, now let $P$ be a minimal prime of $R$ (since $M$ is nonzero and thus $R$ is nonzero, we know $R$ has a minimal prime ideal). We then have an injective homomorphism $M_P^m\to M_P^n$ of $R_P$-modules. But the ring $R_P$ is a zero-dimensional Noetherian ring and thus is Artinian, so $M_P$ has finite length over $R_P$. If $M_P$ has length $\ell$, then $M_P^m$ has length $m\ell$ and $M_P^n$ has length $n\ell$, and so our injective homomorphism implies $m\ell\leq n\ell$. Since $M_P$ is nonzero, $\ell>0$, so we conclude that $m\leq n$.
As a final remark, the assumption that $M$ is faithful is unnecessary, since we can always replace $R$ with the quotient $R/\mathrm{Ann}(M)$ over which $M$ is faithful.
Eric Wofsey
  • 330,363
