I am looking for numerical evidence that $$\sum_{m\geq1}\sum_{n\geq1}\frac{(-1)^n}{n^3}\sin\left(\frac{n}{m^2}\right)=\frac{\pi^6}{11340}-\frac{\pi^4}{72}$$ I have proven it, but I just want to be extra sure. Desmos only gives me accuracy to the third decimal place, but I know that some of you (@Claude Leibovici) are able to give me extremely high decimal accuracy.
Proof:
We know that for $|t|\leq\pi$, $$t^2=\frac{\pi^2}3+4\sum_{n\geq1}\frac{(-1)^n}{n^2}\cos nt$$ Solving for the sum then integrating both sides from $0$ to $x$, $$\sum_{n\geq1}\frac{(-1)^n}{n^3}\sin(nx)=\frac{x^3}{12}-\frac{\pi^2x}{12}$$ Then plugging in $x=\frac1{m^2}$ for integer $m\geq1$, $$\sum_{n\geq1}\frac{(-1)^n}{n^3}\sin\bigg(\frac{n}{m^2}\bigg)=\frac{1}{12m^6}-\frac{\pi^2}{12m^2}$$ then applying $\sum_{m\geq1}$ on both sides, $$\sum_{m\geq1}\sum_{n\geq1}\frac{(-1)^n}{n^3}\sin\bigg(\frac{n}{m^2}\bigg)=\frac1{12}\zeta(6)-\frac{\pi^2}{12}\zeta(2)$$ We simplify to reach our conclusion $$\sum_{m\geq1}\sum_{n\geq1}\frac{(-1)^n}{n^3}\sin\bigg(\frac{n}{m^2}\bigg)=\frac{\pi^6}{11340}-\frac{\pi^4}{72}$$
Did
  • 279,727
clathratus
  • 17,161
After you so elegant solution, I am quite ashamed to have done it the following way.
$$\sum_{n=1}^\infty\frac{(-1)^n}{n^3}\sin(nx)=\frac{i}{2} \left(\text{Li}_3\left(-e^{-i x}\right)-\text{Li}_3\left(-e^{i x}\right)\right)$$
Replace $x=\frac 1 {m^2}$ and numerically compute $$\frac{i}{2}\sum_{m=1}^\infty \left(\text{Li}_3\left(-e^{-\frac i {m^2} }\right)-\text{Li}_3\left(-e^{\frac i {m^2}}\right)\right)$$
It takes a long time to arrive to $-1.268125453640218644419$.
Update
I watched the news, I read the newspaper, I had a heavy breakfast and came back to my computer $$-1.26812545364021864441879478985797582963162172461540$$
Edit
I tried to understand why this computation was taking so much computing time.
Let us consider $$a_m=\frac{i}{2} \left(\text{Li}_3\left(-e^{-\frac i {m^2} }\right)-\text{Li}_3\left(-e^{\frac i {m^2}}\right)\right)$$ For large values of $m$, we have $$a_m=-\frac{\pi ^2}{12 m^2}+\frac{1}{12 m^6}+O\left(\frac{1}{m^{14}}\right)$$ So $$\sum_{m=1}^\infty a_m\simeq\sum_{m=1}^p a_m+\sum_{m=p+1}^\infty\left(-\frac{\pi ^2}{12 m^2}+\frac{1}{12 m^6} \right)=\sum_{m=1}^p a_m+\frac{\psi ^{(5)}(p+1)-120 \pi ^2 \psi ^{(1)}(p+1)}{1440}$$ and the last term is almost $$\frac{\psi ^{(5)}(p+1)-120 \pi ^2 \psi ^{(1)}(p+1)}{1440}\simeq -\frac{\pi^2}{12p}\left(1-\frac{1}{2 p}+\frac{1}{6 p^2}+O\left(\frac{1}{p^4}\right) \right)$$ In other words, for $k$ significant figures, we need to add a lot terms.
This explains that.
  • Elegant or not, I really appreciate the answer. Thanks Claude :) – clathratus Dec 25 '18 at 04:07
    @clathratus. It is not only elegant; it is beautiful ! Beauty is part of mathematics. – Claude Leibovici Dec 25 '18 at 04:12
  • Nice! Mind if I ask you what programm do you use for such computations? – Zacky Dec 25 '18 at 15:04
  • @Zacky. I have an old CAS that, in my group over more than twenty years, we adapted to our specific needs. I suppose that this could easily be done using Mathematica. – Claude Leibovici Dec 25 '18 at 15:09
  • I see, pretty nice, I only have the online version for Mathematica. If you have some free time, can you please check it's power against this? $$\int_0^\infty \frac{1-\cos x}{8-4x\sin x +x^2(1-\cos x)}dx=\frac{\pi}{4}$$ My wolfram can't even spit $1$ decimal out... So I would be glad if I know that the result it's correct. It is $I_5$ that I put here: https://math.stackexchange.com/a/3027759/515527 – Zacky Dec 25 '18 at 15:11
  • @Zacky. I have terrible integration problems with that one ! I shall try to work it later. – Claude Leibovici Dec 25 '18 at 15:18
  • Thans you and no problem! There is no rush. – Zacky Dec 25 '18 at 15:20
