So far I have that if I + J = R, then 1 ∈ I and/or 1 ∈ J. Then I = R and/or J = R. If both I = J = R, then IJ = I ∩ J = R must be true because we already know that multiplying every element in I or J by every element in R will end up giving us R again. So IJ = I ∩ J = R.
If I = R, but J ≠ R, then IJ = J = I ∩ J because we already know that when all elements of J are multiplied by all elements of R, the result is J again. Therefore, IJ = I ∩ J = J.
Therefore, it is true that if I + J = R, then IJ = I ∩ J.
Does this proof work or am I not able to say that 1 ∈ I or 1 ∈ J?
Jon D.
  • 71
    "if I + J = R, then 1 ∈ I and/or 1 ∈ J" This is not true. You need a completely different argument. – darij grinberg Dec 10 '18 at 23:51
  • How does $I+J = R$ imply that $1 \in I$ or $1 \in J$? This is false: consider for instance the ideals $2 \mathbb{Z}$ and $3 \mathbb{Z}$ in $\mathbb{Z}$. Then $1 = -2 + 3 \in 2 \mathbb{Z} + 3 \mathbb{Z}$, but $1 \notin 2\mathbb{Z}$ and $1 \notin 3 \mathbb{Z}$. – Viktor Vaughn Dec 10 '18 at 23:52
  • Try $I \cap J(I+J)$ – Andres Mejia Dec 10 '18 at 23:54
Hint:
$IJ\subset I\cap J$ is trivial. For the reverse inclusion:
By hypothesis, there exist $u\in I$, $v\in J$ such that $u+v =1$. Now let $x\in I\cap J$. Use that $x=1\cdot x$.
Bernard
  • 175,478
  • Why do you consider the first line to be trivial? Am I missing something obvious about multiplying ideals? – Jon D. Dec 11 '18 at 00:11
  • It is indeed obvious. Check the definition of a product of ideals. – Bernard Dec 11 '18 at 00:27
  • I've been trying to find a good one, my professor never taught us about adding and multiplying ideals, so this question blindsided me a bit. – Jon D. Dec 11 '18 at 00:45
  • Ok, correct me if I'm wrong, but to get the product, you essentially multiply every element of I by every element of J and then also see what else you can make by adding and subtracting those products you already made? – Jon D. Dec 11 '18 at 00:54
  • Yes. Isn't each of these products in $I\cap J$? – Bernard Dec 11 '18 at 01:05
