The OP states
It seems to almost be the same as the sieve of Eratosthenes except it starts with a small list of known prime numbers?
That is correct. If you start off with just first two primes, $2$ and $3$ you can mark off all numbers that are a multiple of either one. For the theory here see
Is that true that all the prime numbers are of the form $6m \pm 1$?
Notice that $6 = 2 \times 3$ in the above Q/A thread.
What about screening for just $2$, $3$, and $5$? The core 'guts' for this $2 \times 3 \times 5 = 30$ wheel algorithm is it has to start 'spitting out' prime number candidates with the actual spot on prime number $7$. It employs a $\text{modulo-}30$ logic but after awhile it can output composite numbers. Still, more numbers will be excluded than by using only the simple $6m \pm 1$ screen.
The algorithm doesn't hit $30$, but the $2$, $3$, and $5$ Eratosthenes exclusions all simultaneously meet and are 'reset' at that number,
$\quad 30 = 2 \times 15 \; \text{exclude } 30 + 2, 30+4, \dots$
$\quad 30 = 3 \times 10 \; \text{exclude } 30+3, 30+6, \dots$
$\quad 30 = 5 \times 6 \; \;\,\text{exclude } 30+5, 30+10, \dots$
and we are ready to 'turn the wheel' again.
In a comment the OP states they are not confident about the programming for a wheel. The approach here always works. You know exactly where the primes are on your initial step by step traversal of length $30$ (or any other length wheel) and of course the exclusions are the complement of this set. So you just have to step over the composites and then program for the simultaneous meet/reset.
Following is a Python algorithm for the $2 \times 3 \times 5 = 30$ 'spit out'. We have it stopping when the output is $77$, which is a composite of the primes $7$ and $11$ which do not belong to $\{2,3,5\}$.
Python Program
def Z30_Sieve():
spot = Z30_sieve_sv[0]
pc = Z30_sieve_sv[spot] + 30
Z30_sieve_sv[spot] = pc
spot = spot + 1
if spot < len(Z30_sieve_sv):
Z30_sieve_sv[0] = spot
else:
Z30_sieve_sv[0] = 1
return pc
Z30_sieve_sv = [2, 1, -23, -19, -17, -13, -11, -7, -1]
for i in range(0, 20):
print( Z30_Sieve() , Z30_sieve_sv)
OUTPUT
7 [3, 1, 7, -19, -17, -13, -11, -7, -1]
11 [4, 1, 7, 11, -17, -13, -11, -7, -1]
13 [5, 1, 7, 11, 13, -13, -11, -7, -1]
17 [6, 1, 7, 11, 13, 17, -11, -7, -1]
19 [7, 1, 7, 11, 13, 17, 19, -7, -1]
23 [8, 1, 7, 11, 13, 17, 19, 23, -1]
29 [1, 1, 7, 11, 13, 17, 19, 23, 29]
31 [2, 31, 7, 11, 13, 17, 19, 23, 29]
37 [3, 31, 37, 11, 13, 17, 19, 23, 29]
41 [4, 31, 37, 41, 13, 17, 19, 23, 29]
43 [5, 31, 37, 41, 43, 17, 19, 23, 29]
47 [6, 31, 37, 41, 43, 47, 19, 23, 29]
49 [7, 31, 37, 41, 43, 47, 49, 23, 29]
53 [8, 31, 37, 41, 43, 47, 49, 53, 29]
59 [1, 31, 37, 41, 43, 47, 49, 53, 59]
61 [2, 61, 37, 41, 43, 47, 49, 53, 59]
67 [3, 61, 67, 41, 43, 47, 49, 53, 59]
71 [4, 61, 67, 71, 43, 47, 49, 53, 59]
73 [5, 61, 67, 71, 73, 47, 49, 53, 59]
77 [6, 61, 67, 71, 73, 77, 49, 53, 59]
