I was recently watching blackpenredpen’s video (found here: https://m.youtube.com/watch?v=UJ3Ahpcvmf8) where he found the derivative of the the function $y = x^{x^x}$. Before watching the video, I decided to try it myself, and I didn’t it this way: Firstly I decided I would use the chain rule and define two functions, $u(x)$ and $v(x)$, both of which are $x^x$, so I could show the function as $u(v(x))$. Using the chain rule, the derivative would be: $u’(v(x))\cdot v’(x)$. We can find the derivative of $x^x$ (as shown on Quora here: https://www.quora.com/What-is-the-derivative-of-x-x-How-could-I-derive-it-as-well) as $x^x\cdot(\ln x+1)$. Now using the chain rule to get $u’(v(x))$ we get ${(x^x)}^{(x^x)}\cdot(\ln {x^x}+1)$ or $x^{x^{x+1}}\cdot(\ln {x^x}+1)$. This wasn’t the answer that blackpenredpen arrived at though. In the video, he arrived at $x^x\cdot x^{x^x}\left({\frac{1}{x}+\ln x+(\ln x)^2}\right)$. I can’t see how he did it, and I’m sure that it is right. If anyone could confirm my answer or show where I went wrong it would be greatly appreciated. Thanks.
2note that $u(v(x))=v(x)^{v(x)}=(x^x)^{x^x}$, what is not the same function. Instead try the following: $x^{(x^x)}=\exp(x^x\ln x)=\exp(e^{x\ln x}\ln x)$, now use the chain rule. – Masacroso Nov 15 '18 at 06:10
@Masacroso Are you sure? Exponentiation is left associative so $\alpha^{\alpha^\alpha}$ = $\alpha^{(\alpha^\alpha)}$. So wouldn’t ${(x^x)}^{x^x} = {(x^x)}^{(x^x)}$? – Logan M Nov 15 '18 at 06:19
Yes, that is right. But the way I (tried) to find $\frac{d}{dx}\left[{x^{x^x}}\right]$ lead me to get a ${(x^x)}^{(x^x)}$ in my answer, this is probably where I’ve gone wrong. Note: this was in response to another comment, which seems to have been deleted. – Logan M Nov 15 '18 at 06:28
For differentiating expressions of the form $u(x)^{v(x)},$ I've always found it easiest to take logarithms and then differentiate implicitly. However, rather than work with the more general form $y = u^v,$ I'll work with $y = x^U$ (i.e. use $x$ for the base), which is sufficient to deal with $x^{x^x}.$
Taking the logarithm of both sides gives
$$ y = x^U \;\; \implies \ln y = \ln\left(x^U \right) \;\; \implies \;\; \ln y = U \cdot \ln x $$
Now differentiate both sides with respect to $x$:
$$ \frac{d}{dx}\left(\ln y\right) \;\; = \;\; \frac{d}{dx}\left(U \cdot \ln x \right) $$
$$ \frac{y'}{y} \;\; = \;\; \frac{d}{dx}(U) \cdot \ln x \; + \; U \cdot \frac{d}{dx} (\ln x) \;\; = \;\; U'\ln x \; + \; \frac{U}{x} $$
$$ y' \;\; = \;\; y \cdot \left[ U'\ln x \; + \; \frac{U}{x} \right] \;\; = \;\; x^U \cdot \left[ U'\ln x \; + \; \frac{U}{x} \right] $$
Using this result for $U(x) = x,$ we get
$$ \left(x^x\right)' \;\; = \;\; x^x \cdot \left[ 1 \cdot \ln x \; + \; \frac{x}{x} \right] \;\; = \;\; x^x(\ln x + 1) $$
Using that same result for $U(x) = x^x$ along with what we just found for $\left(x^x\right)',$ we get
$$ \left(x^{x^x}\right)' \;\; = \;\; x^{x^x} \cdot \left[ \left(x^x\right)' \cdot \ln x \; + \; \frac{x^x}{x} \right] $$
$$ \left(x^{x^x}\right)' \;\; = \;\; x^{x^x} \cdot \left[ x^x(\ln x + 1) \cdot \ln x \; + \; \frac{x^x}{x} \right] $$
$$ \left(x^{x^x}\right)' \;\; = \;\; x^{x^x} \cdot x^x \cdot \left[ (\ln x + 1)\ln x \; + \; \frac{1}{x} \right] $$
$$ \left(x^{x^x}\right)' \;\; = \;\; x^{x^x} \cdot x^x \cdot \left[ (\ln x)^2 \; + \; \ln x \; + \; \frac{1}{x} \right] $$
- 36,843
You can apply the method given on quora to your problem: $$\left(x^{x^x}\right)'=\left(e^{x^x\ln x}\right)'=e^{x^x\ln x}\cdot \left(x^x\ln x\right)'=\\ =e^{x^x\ln x}\cdot \left(e^{x\ln x}\ln x\right)'=\\ =e^{x^x\ln x}\cdot \left[\left(e^{x\ln x}\right)'\ln x+e^{x\ln x}\cdot \frac1x\right]=\\ =x^{x^x}\cdot \left[e^{x\ln x}\left(x\ln x\right)'\ln x+x^x\cdot \frac1x\right]=\\ =x^{x^x}\cdot \left[x^x\left(\ln x+1\right)\ln x+x^x\cdot \frac1x\right]=\\ =x^{x^x}\cdot x^x\left[\ln^2 x+\ln x+\frac1x\right].$$ P.S. I could not watch the referenced video on Youtube, because it is not opening here (it might be blocked).
- 31,482
Sorry about the video, he did almost exactly the same thing that you did, but might I ask, would you be able to show me where I went wrong? – Logan M Nov 15 '18 at 07:49
If $u(x)=x^x, v(x)=x^x$, then $u(v(x))=(x^x)^{x^x}=x^{x^{x+1}}$, which is a different function. – farruhota Nov 15 '18 at 07:54
Oh, I see, $u(v(x))$ would have been $x^{x^x}$ of course. That’s a bit embarrassing... – Logan M Nov 15 '18 at 07:56
