How can we use Fermat's Little Theorm to find the least non-negative residue modulo m with numbers with large exponents. For example, how would one find the least non-negative residue modulo m with values $n = 3^{1000000}$ and $m = 19$.
I understand how the basic method works (ie finding a way to introduce a factor of $3^{18}$ and then reducing), but dividing 1000000 by 18 is time consuming and I feel there is a quicker method that I don't understand yet.
$$3^{18}\equiv 1 \text{ mod 19}$$ $$3^{18*55555}\equiv 1 \text{ mod 19}$$ $$3^{999990}\equiv 1\text{ mod 19}$$ $$3^{1000000}\equiv 3^{10} \text{ mod 19}$$ $$3^{1000000}\equiv 16\text{ mod 19}$$
Ethan Splaver
  • 10,613
Hint $\rm\ mod\ 9\!:\, 10^6\equiv 1^6\equiv 1,\,\ mod\ 2\!:\, 10^6\equiv 0,\ $ so $\rm\ mod\ 18\!:\, 10^6\equiv 10,\,$ so $\rm\,mod\ 19\!:\ 3^{10^6}\!\equiv 3^{10}$
Alternatively $ $ we may employ Euler's Criterion and quadratic reciprocity:
$$\rm\quad mod\ 19\!:\,\ \color{#C00}{3^9} \equiv \left(\frac{3}{19}\right) \equiv\, -\left(\frac{19}{3}\right)\equiv\, -\left(\frac{1}{3}\right)\equiv\,\color{#C00}{-1}$$
$\rm 10^6\!-1 = 9k,\ k\ odd,\,$ so $\rm\, mod\ 19\!:\ 3^{10^6} = 3^{1+9k} =\, 3 (\color{#C00}{3^9})^k\equiv 3 (\color{#C00}{-1})^k\equiv -3$
Math Gems
  • 19,574
  • I assume your using some theorem that allows you to multiply mod values, can you tell me the name of the theorem or give a little explanation as to how this whole thing works – Math_Illiterate Feb 10 '13 at 06:40
  • $\rm mod\ 9!: 10^6\equiv 1,:$ so $\rm:mod\ 18!: 10^6\equiv 1\ \ or\ \ 1+9=10.:$ Since $\rm,10^6,$ is even, it must be $10.:$ Generally one can use CRT (Chinese Remainder), but that'd be overkill here. – Math Gems Feb 10 '13 at 06:50
  • @MathGems It was overkill once you started adding colors lol – Ethan Splaver Feb 10 '13 at 07:16
    @Ethan The colors greatly aid the reader to follow the structure of the inferences. E.g. when I wrote equational inferences like above in older systems without such highlight capabilities, I often received questions, e.g. why is the penultimate congruence true? With it and its source both highlighted in red, one easily sees that it is an application of the replacement rule $\rm: a\equiv b:\Rightarrow:f(a)\equiv f(b),:$ where $\rm:f(n) = 3n^k,:$ and $\rm,a= 3^9,,b= -1.\ \ $ In more complex proofs, this structure may be much less clear. – Math Gems Feb 10 '13 at 16:27
In fact, finding the remainder of $10^6$ by $18$ is not really that tough
Observe that $10^{n+1}-10=10(10^n-1)$ is divisible by $10\cdot 9=90,$ as $9\mid(10^n-1)$ for $n\ge1$
Hence $18\mid(10^{n+1}-10)\implies 10^{n+1}\equiv10\pmod{18}$ for $n\ge1$
So, $$3^{10^n}\equiv3^{10}\pmod {19} \text{ for } n\ge1$$
Modular arithmetic makes this easy.
To find 1000000 modulo 18, we can first find 100000 modulo 18, and then multiply by 10 and reduce modulo 18 again.
To find 100000 modulo 18, we can first find 10000 modulo 18, and then multiply by 10 and reduce modulo 18 again.
To find 10000 modulo 18....
