Yesterday in class, we were analyzing the Karatsuba multiplication algorithm and how it applies to recurrence equations. Time ran short, and I feel I missed how to solve the final summation.
First, we defined the recurrence equation as
$$T(n) = 3T \left(\frac{n}{2}\right) + 4n$$
and applied a recurrence tree such like
$$T(n) = 3T \left(\frac{n}{2}\right) + 4n \Rightarrow 4n \cdot \left(\frac{3}{2}\right)^0$$
$$T\left(\frac{n}{2}\right) = 3T \left (\frac{n}{4} \right) + 4\left(\frac{n}{2}\right) \Rightarrow 4n \cdot \left(\frac{3}{2}\right)^1$$
$$T\left(\frac{n}{4}\right) = 3T \left (\frac{n}{8} \right) + 4\left(\frac{n}{4}\right) \Rightarrow 4n \cdot \left(\frac{3}{2}\right)^2$$
$$T\left(\frac{n}{8}\right) = 3T \left (\frac{n}{16} \right) + 4\left(\frac{n}{8}\right) \Rightarrow 4n \cdot \left(\frac{3}{2}\right)^3$$
Because the denominiator increases in a logarithmic fashion, we defined the summation as
$$\sum_{x=0}^{log_2n} 4n \cdot \left(\frac{3}{2}\right)^x$$
Time was running short, so several steps were skipped, and the final solution was given as
$$9\cdot 3^{log_2n} = 9n^{log_23} = 9n^{1.58} = O(n^{1.58})$$
based on the properties
$$a^{lg\, b} = b^{lg\, a}\: \text{and}\: log_2 3 \approx 1.58$$
I've tried applying the summation formula
$$\sum_{x=0}^{n}r^x = \frac{r^{n+1}-1}{r-1}$$
with this result, and end up with
$$\sum_{x=0}^{n}r^x = \frac{r^{n+1}-1}{r-1} = \sum_{x=0}^{log_2 n} 4n \cdot \left(\frac{3}{2}\right)^x $$
$$= 4\left(n\cdot \frac{\frac{3}{2}^{lg_2n+1}-1}{\frac{3}{2}-1}\right) = 4\left(n \cdot \frac{\frac{3}{2}^{log_2n+1}-1}{\frac{1}{2}}\right) = 2\left(n \cdot \frac{3}{2}^{log_2n+1}+1\right) $$
$$=2n \cdot 3^{log_2n+1} + 2$$
which is very different than the solution given. Where did I go wrong?
