Given that $$5\cos(x)-12\sin (x) = 13 $$
I'm trying to evaluate the general solution for that expression. It reminds me of $5-12-13$ triangle. Since we don't know the degree of $x$, I couldn't proceed further. Specifically, let's take its derivate, which yields
$$\dfrac{d}{dx} 5\cos(x)-12\sin (x) = 13 = 0$$
Busi
  • 572
  • What would taking the derivative do? You’re solving an equation, if you have $x+1=2$ and you take the derivative on both sides what does that show?? – Teh Rod Sep 02 '18 at 20:53
  • See https://math.stackexchange.com/questions/757497/find-4-cos-theta-3-sin-theta-given-that-4-sin-theta-3-cos-theta-5/757498#757498 – lab bhattacharjee Sep 03 '18 at 06:08
  • @Teh Rod: It is interesting that for this particular type of equation differentiating both sides works: it immediately leads to the solution between $0$ and $2\pi$; $\tan ^{-1}\left(-\frac{12}{5}\right)=-\tan ^{-1}\left(\frac{12}{5}\right)$ – James Arathoon Sep 03 '18 at 09:05
  • You should have written above $$\dfrac{d}{dx} \left( 5\cos(x)-12\sin (x) \right) = \dfrac{d}{dx} (13) = 0$$ – James Arathoon Sep 03 '18 at 09:11
5 Answers5
HINT
For these kind of equations we can use by $t=\tan \frac {x} 2$ with $\frac {x} 2 \neq\frac{\pi}2+k\pi$ (which in that case are not solutions) the following identities
  • $\sin (x) =\frac{2t}{1+t^2}$
  • $\cos (x) =\frac{1-t^2}{1+t^2}$
to obtain a quadratic equation in $t$ that is
$$5\frac{1-t^2}{1+t^2}-12\frac{2t}{1+t^2}=13 \iff 9t^2+12t+4=(3t+2)^2=0$$
As an alternative we can also use the following
  • $a\sin x+b\cos x=c\sin(x+\varphi)$
  • $c = \sqrt{a^2 + b^2}$
  • $\varphi = \operatorname{atan2} \left( b, a \right)$
user
  • 154,566
This has a general method: divide the whole equation by $\;\sqrt{5^2+12^2}=13\;$ , so the equation becomes
$$\frac5{13}\cos x-\frac{12}{13}\sin x=1$$
Since $\;\left(\frac5{13}\right)^2+\left(\frac{12}{13}\right)^2=1\;$ , there exists $\;\alpha\in\Bbb R\;$ (in fact, we can choose this value in an infinite number of ways...) such that $\;\cos\alpha=\frac{12}{13}\;,\;\;\sin\alpha=\frac5{13}\;$ , so the equations becomes
$$\sin\alpha\cos x-\sin x\cos\alpha=1\stackrel{\text{trig. identity}}\iff\sin(\alpha-x)=1\ldots$$
Try now to take it from here. And BTW: some high schools specifically forbid to use calculus when solving trigonometric equations!
DonAntonio
  • 211,718
  • 136
  • 287
Hint By Cauchy Schwarz you have $$169=13^2=(5\cos(x)-12\sin (x))^2 \leq (5^2+12^2)(\cos^2(x)+\sin^2(x))=169$$
Therefore, you must have equality in CS, and hence $$\frac{\cos(x)}{5}=\frac{\sin(x)}{-12}$$ Now combine this equality with $$\sin^2(x)+\cos^2(x)=1$$
N. S.
  • 132,525
  • What was the reason you used Cauchy Schwarz? I would like to know that for future questions like this one. – Busi Sep 02 '18 at 20:53
  • @Busi I simply recognized that $5,12,13$ is a Pythagorean triple. $$5\cos(x)-12\sin (x) = 13\5^2+12^2=13^2$$ suggests CS. – N. S. Sep 02 '18 at 23:12
  • @Busi For the equality case of CS, see one of these questions : https://math.stackexchange.com/search?q=cauchy+schwarz+equality – Arnaud D. Sep 03 '18 at 14:39
Hint: the left-hand side is $13\cos (x+\arctan\frac{12}{5})$, so you have to set a cosine to $1$.
J.G.
  • 115,835
The expression $a\cos x+ b\sin x$ can be rewritten as one of
\begin{cases} a\cos x+ b\sin x=r\cos(x-\varphi)\\a \sin x + b \cos x = r\sin(x+\varphi) \end{cases}
where $r=\sqrt{a^2+b^2}$, $\varphi=\arctan(b/a)$ if $a>0$, $\varphi=\pi+\arctan(b/a)$ if $a<0$
We use the first equation, $a=5, b=-12$:
$$\sqrt{5^2+12^2}\cos(x-\arctan(-\frac{12}{5}))=13$$
Divide both sides by 13
$$\cos(x-\arctan(-\frac{12}{5}))=1$$
The cos function is only 1 for $n2\pi$, $\arctan(-u)=-\arctan(u)$
$$x+\arctan(12/5)=n2\pi,\quad n\in \mathbb{z}$$
$$\boxed{x=n2\pi-\arctan(\frac{12}{5}),\quad n\in \mathbb{z}}$$
ContraKinta
  • 1,652
