An extremely detailed explanation is given in the post "Making Formulas… for Everything—From Pi to the Pink Panther to Sir Isaac Newton
" by Michael Trott on the Wolfram Blog. A brief excerpt:
Assume you make a line drawing with a pencil on a piece of paper, and assume you draw only lines; no shading and no filling is done. Then the drawing is made from a set of curve segments. The mathematical concept of Fourier series allows us to write down a finite mathematical formula for each of these line segments that is as close as wanted to a drawn curve.
We want a single formula for the whole equation, even if the formula is made from disjoint curve segments. To achieve this, we use the 2π periodicity of the Fourier series of each segment to plot the segments for the parameter ranges [0, 2π], [4π, 6π], [8π, 10π], …, and in the interleaving intervals (2π, 4π), (6π, 8π), …, we make the curve coordinates purely imaginary. As a result, the curve cannot be drawn there, and we obtain disjoint curve segments. ...
