I am given a problem to find the mapping corresponding to the following matrix $\left[\begin{array}{cc} -\frac{1}{2} & \frac{\sqrt{3}}{2}\\ -\frac{\sqrt{3}}{2} & -\frac{1}{2} \end{array}\right]$ Now using the eigenvalue equation $M(r)=r$, I found two equations $y=\sqrt{3}x$ and $y=-\frac{1}{\sqrt{3}}x$ and these are two straight lines crossing at the origin. I am a bit confused about how to find the axis of rotation from these information.
1This is a rotation of the plane. There is no axis. Or, the rotation is about the origin. Rotations in $\Bbb{R}^3$ have an axis. In higher dimensions it depends on your definition. – Jyrki Lahtonen Aug 13 '18 at 04:55
1I’d be curious to see how you came up with these eigenvectors, since $1$ isn’t even an eigenvalue of this matrix. The only solution to $Mr=r$ is the zero vector. – amd Aug 13 '18 at 05:02
1@amd I think that, in solving for eigenvectors for non-eigenvalue $1$, the asker found themselves solving those two equations simultaneously, and also arrived at the conclusion that the only solution was the $0$ vector. – Theo Bendit Aug 13 '18 at 05:21
@amd, I simply thought that there should be some rotation axis the vectors along which would remain the same under the matrix operation. I took this idea from a 3 by 3 matrix which may correspond to a rotation about some axis. Now as has been commented above, there is no axis for this 2 by 2 matrix since this corresponds to a rotation in plane devoid of a third axis. Is there something wrong here? – StudentofPhysics Aug 13 '18 at 15:09
The idea of an axis of rotation is pretty much unique to three-dimensional spaces. In general, a rotation takes place in some plane. The orthogonal complement of this plane remains unaffected by the rotation. In three dimensions, this space is one-dimensional, so you can identify a single line through the center of rotation as its axis. In higher-dimensional spaces, this complementary space has more than one dimension, so there’s no unique line that is left fixed by it. (One could by extension call this space the “axis,” but I’ve not found that very useful.) In a two-dimensional space, there’s nothing outside of the plane of rotation, which is the entire space, so it doesn’t really make sense to speak of a rotation axis there, either. You often see this done, anyway, but doing so views the plane as embedded in a three-dimensional space instead of standing on its own.
You can identify a fixed point in the plane of rotation, though. This is the center of rotation within the rotation plane and makes sense in any number of dimensions. For a rotation that’s a linear transformation like your example, this will always be the origin.
Now, you can certainly find the axis of a 3-D rotation matrix by computing eigenvectors of $1$, but that works because $1$ is always an eigenvalue of a 3-D rotation and as I noted above, the subspace that’s left unchanged by a nontrivial 3-D rotation is one-dimensional. As you discovered, the only solution of the equation $Mv=v$ for your 2-D rotation is $(0,0)$, but that’s to be expected because $1$ isn’t an eigenvalue of $M$—the only point that gets mapped to itself is the origin.
- 53,693
Wouldn't there be an axis of rotation for any $n-1$ dimensional hyperplane in $\Bbb{R}^n?$ – Chickenmancer Aug 13 '18 at 20:47
@Chickenmancer Rotations occur in planes—two-dimensional flats—regardless of the dimensionality of the space they’re embedded in. – amd Aug 13 '18 at 22:38
1+1 of course. The description of a rotation as moving only points of a plane, and leaving the $(n-2)$-dimensional orthogonal complement fixed pointwise, is fine. But it has the shortcoming that, unless $n\le3$, they don't form a group. To remedy that we can also declare that linear transformations with matrices $A$ satisfying $A^TA=I_n, \det A=1$, could all be called rotations. In that case there may be several angles of rotation. See here for more discussion about rotations in nD. – Jyrki Lahtonen Aug 14 '18 at 04:29
@JyrkiLahtonen Indeed. Things can get quite interesting once you start combining these “basic” rotations in various ways. – amd Aug 14 '18 at 20:16
