This is Problem 2-15(c) from Spivak's Calculus on Manifolds.
Problem 2-15(c). If $\det(a_{ij}(t)) \neq 0$ for all $t$ and $b_1,\dots,b_n : \mathbb{R} \to \mathbb{R}$ are differentiable, let $s_1,\dots,s_n : \mathbb{R} \to \mathbb{R}$ be the functions such that $s_1(t),\dots,s_n(t)$ are the solutions of the equations $$ \sum_{j=1}^n a_{ji}(t) s_j(t) = b_i(t) \qquad i = 1,\dots,n. $$ Show that $s_i$ is differentiable and find ${s_i}'(t)$.
It is also given (in part (b) of the same problem) that the $a_{ij}$'s are taken to be differentiable.
I am presenting my solution below, followed by my question.
Let $A(t) = (a_{ij}(t))$ be an $n \times n$ matrix for each $t$. Then, the given system of equations corresponds to $$ S(t) A(t) = B(t), $$ where $$S(t) = \begin{bmatrix} s_1(t) & \cdots & s_n(t) \end{bmatrix}$$ and $$B(t) = \begin{bmatrix} b_1(t) & \cdots & b_n(t) \end{bmatrix}.$$ Let $$ A_i(t) = \begin{bmatrix} a_{11}(t) & \cdots & a_{1n}(t) \\ \vdots & & \vdots \\ b_1(t) & \cdots & b_n(t) \\ \vdots & & \vdots \\ a_{n1}(t) & \cdots & a_{nn}(t) \end{bmatrix}, $$ where the $b_i$'s are inserted in the $i$th row. Then, by Cramer's Rule, $$ s_i(t) = \frac{\det A_i(t)}{\det A(t)}. $$ Problem 2-15(b) shows that $\det A_i(t)$ and $\det A(t)$ are differentiable, and so $s_i$ is differentiable for each $1 \leq i \leq n$. To compute ${s_i}'(t)$ we can use the chain rule. $\tag*{$\blacksquare$}$
My problem is that after applying the chain rule, I get a huge ugly expression with no means of simplifying it in sight. It doesn't look like the functions ${s_i}'(t)$ have any natural interpretation.
Now, I wouldn't put it past Spivak to ask the student to perform a lengthy calculation just for the sake of it (after all, that's what Problem 2-10 was all about). But I still can't help but feel I'm missing something here. Especially since he asks us to redo the computation later (Problem 2-40) using the Implicit Function Theorem.
Can anyone tell me if I'm proceeding in the right direction, or if there is another (perhaps more illuminating) way to solve this problem?
I'm stating Problem 2-15(b) below for completeness.
Problem 2-15(b). If $a_{ij} : \mathbb{R} \to \mathbb{R}$ are differentiable and $f(t) = \det(a_{ij}(t))$, show that $$ f'(t) = \sum_{j=1}^n \det \begin{bmatrix} a_{11}(t) & \cdots & a_{1n}(t)\\ \vdots & & \vdots \\ {a_{j1}}'(t) & \cdots & {a_{jn}}'(t) \\ \vdots & & \vdots \\ a_{n1}(t) & \cdots & a_{nn}(t) \end{bmatrix}. $$
I would use vector / matrix notation.
You have
$$S(t)=\left(A(t)\right)^{-1}.B(t)$$
Knowing that $\left(A^{-1}\right)^\prime(t)=-A^{-1}(t) A^\prime(t) A^{-1}(t)$ you get
$$S^\prime(t)=-A^{-1}(t) A^\prime(t) A^{-1}(t)B(t) +A^{-1}(t)B^\prime(t)=A^{-1}(t)\left(-A^\prime(t)S(t)+B^\prime(t)\right)$$
I think I have managed to simplify the expression for ${s_i}'(t)$ into something reasonable. I am posting my work here as an answer. Again, any comments or suggestions would be appreciated.
Let $f,g_1,\dots,g_n : \mathbb{R} \to \mathbb{R}$ by $f(t) = \det A(t)$ and $g_i(t) = \det A_i(t)$. Then, $$ s_i(t) = \frac{g_i(t)}{f(t)}, $$ so by the chain rule we have $$ \begin{align} {s_i}'(t) &= \frac{f(t) {g_i}'(t) - g_i(t) f'(t)}{f(t)^2}\\ &= \frac{f(t) {g_i}'(t) - s_i(t) f(t) f'(t)}{f(t)^2}\\ &= \frac{{g_i}'(t) - s_i(t) f'(t)}{f(t)}. \end{align} $$ Now, we observe that $$ {g_i}'(t) = \sum_{\substack{j = 1\\j \neq i}}^n \det \begin{bmatrix} a_{11}(t) & \cdots & a_{1n}(t)\\ \vdots & & \vdots\\ {a_{j1}}'(t) & \cdots & {a_{jn}}'(t)\\ \vdots & & \vdots\\ b_1(t) & \cdots & b_n(t)\\ \vdots & & \vdots\\ a_{n1}(t) & \cdots & a_{nn}(t) \end{bmatrix} +\det \begin{bmatrix} a_{11}(t) & \cdots & a_{1n}(t)\\ \vdots & & \vdots\\ {b_1}'(t) & \cdots & {b_n}'(t)\\ \vdots & & \vdots\\ a_{n1}(t) & \cdots & a_{nn}(t) \end{bmatrix} $$ and $$ s_i(t) f'(t) = \sum_{\substack{j = 1\\j \neq i}}^n \det \begin{bmatrix} a_{11}(t) & \cdots & a_{1n}(t)\\ \vdots & & \vdots\\ {a_{j1}}'(t) & \cdots & {a_{jn}}'(t)\\ \vdots & & \vdots\\ s_i(t) a_{i1}(t) & \cdots & s_i(t)a_{in}(t)\\ \vdots & & \vdots\\ a_{n1}(t) & \cdots & a_{nn}(t) \end{bmatrix} + \det \begin{bmatrix} a_{11}(t) & \cdots & a_{1n}(t)\\ \vdots & & \vdots\\ s_i(t) {a_{i1}}'(t) & \cdots & s_i(t){a_{in}}'(t)\\ \vdots & & \vdots\\ a_{n1}(t) & \cdots & a_{nn}(t) \end{bmatrix}, $$ because $s_i(t)$ is a scalar and so can be multiplied into any one row or column of a determinant, and in particular the $i$th row as we have done here. Hence, $$ {s_i}'(t) = \frac{h(t)}{f(t)} $$ where $$ h(t) = \sum_{\substack{j=1\\ j \neq i}}^n \det \begin{bmatrix} a_{11}(t) & \cdots & a_{1n}(t)\\ \vdots & & \vdots\\ {a_{j1}}'(t) & \cdots & {a_{jn}}'(t)\\ \vdots & & \vdots\\ b_1(t)-s_i(t)a_{i1}(t) & \cdots & b_n(t)-s_i(t)a_{in}(t)\\ \vdots & & \vdots\\ a_{n1}(t) & \cdots & a_{nn}(t) \end{bmatrix}+\det \begin{bmatrix} a_{11}(t) & \cdots & a_{1n}(t)\\ \vdots & & \vdots\\ {b_1}'(t) - s_i(t) {a_{i1}}'(t) & \cdots & {b_n}'(t) - s_i(t){a_{in}}'(t)\\ \vdots & & \vdots\\ a_{n1}(t) & \cdots & a_{nn}(t) \end{bmatrix}. $$
