I am a Young leaner of Mathematics in the university and I found this problem a bit challenging et me.
Please can someone help me integrate
$$\int_{-\infty}^\infty e^{-x^{-2}} dx$$ Thanks.
You probably want $-x^2$, and not $-x^{-2}$, because in the latter case the integral does not converge.
There is no known way to calculate this integral directly. The indirect method involves moving one dimension upwards, and looking at the double integral
$$\int_{-\infty}^{\infty}\int_{-\infty}^{\infty}e^{-x^2-y^2}\,dx\,dy$$
Using some non-trivial theory, it is possible to show that this integral is precisely the square of the integral you are looking for, on one hand, and on the other hand, using some non-trivial theory of coordinate-transformations, it is possible to calculate this double integral directly, by showing that it is equal to the integral $$2\pi\int_0^{\infty}r{e^{-r^2}}\,dr$$ which can actually be easily computed, as the integrand is the derivative of $-e^{-r^2}/2$.
But you need to know a few things in order to get there. Don't waste time on trying to compute it directly. It is probably impossible.
