I'm trying to create a little tool for comparing dice roll probabilities (for table top gaming). I've got a way of calculating "Roll $n$D$s$ pick highest" and "Roll $n$D$s$ and sum" (where $n$ is the number of dice and $s$ is the number of sides on the dice), but I haven't been able to work out how to do "Roll $n$D$s$ and add the highest and lowest".
This answer shows the probability formula for the Nth ordered discrete random variable having a given value.
I assumed that I could get from there to "Roll $n$D$s$ and add the highest and lowest = T" by summing the probabilities of each way to achieve that score (e.g. 5 from $T_1=1,T_n=4$ and $T_1=2,T_n=3$†), where the probability for a pair is the probability of both the case $k=1$ being the lower score and the case $k=n$ being the higher score (i.e. $Pr(X_{(1)} = T_1) \cap Pr(X_{(n)} = T_2)$).
But that isn't working. My best guess is because results are actually related rather than independent, and so $Pr(X_{(n)} = 4)$ includes times when $Pr(X_{(1)} > 1)$ and $Pr(X_{(1)} = 1)$ includes cases where $Pr(X_{(n)} \neq 4)$, and so it's not as simple as ANDing the probabilities of the individual cases.
So, how can I calculate "Probability of rolling $X$ on $n$D$s$ when adding the highest and lowest", or at least $Pr(X_{(1)} = T_1 \cap X_{(n)} = T_2)$ (i.e. both conditions hold on the same roll)?
(A continual WIP JavaScript implementation is currently at https://ibboard.co.uk/dice-roll-compare/temp.html but could be in any state when you read this!)
† or a special case for when $T_1 = T_2$, because there's only one way to roll that on any number of dice! Although the special case might not be necessary if I fix the calculations.
