I'm trying to prove that $a^n+1$ can only be prime if $n$ is a power of $2$. Is there a general factorization of $a^n+1$?
Bill Dubuque
  • 272,048
  • If $n$ is prime then you have $a^n + 1 = (a + u_n^1)(a + u_n^2)\cdots(a + u_n^n)$ where $u_n$ is an $n$th root of unity. – Alex Becker Mar 22 '11 at 23:24
Hint: $\ a^k+1\mid a^n+1\,$ if $\,k\mid n\ $ & $ $ quotient $\,m = n/k\,$ is odd, by
$\bmod\, a^k+1\!:\,\ \color{#c00}{a^k\equiv -1} \Rightarrow\,\ a^n =\, (\color{#c00}{a^k})^m\equiv (\color{#c00}{-1})^m\equiv -1$
Or $ $ put $\ x = a^k\ $ in $\ x+1\mid x^m + 1,\, $ via Factor Theorem: $\ x-c\, \mid\, f(x)-f(c)\ $ in $\ \mathbb Z[x].$
Note the this is simply the case $\,m\,$ odd, $\ x\to -x\ $ in this prior question today.
Bill Dubuque
  • 272,048
For some non-negative integers $b$ and $k$, we have $n=2^b(2k+1)$, in which case
$$a^n+1 = (a^{2^b}+1)(a^{2k\cdot2^b}-a^{(2k-1)2^b}+a^{(2k-2)2^b}-\cdots -a^{3\cdot2^b}+a^{2\cdot2^b}-a^{2^b}+1)$$
If $k>0$ and $a>1$ then this is a factorisation (if $a=1$ then $a^n+1$ is prime); but if $k=0$, i.e. if $n$ is a power of 2, then it leaves you where you started so it is still possible that $a^n+1$ could be prime.
Henry
  • 157,058
