Groups, rings, fields all seem similar to me. I don't get the difference between them.
What is the difference between them algebraically and graphically?
Please give suitable example.
Similar in what sense? The difference between a group and a ring is fundamental: a group is a pair $(G, \circ)$ with some additional axioms. A ring on the other hand is a triple $(R, +, \cdot)$ such that $(R,+)$ is an (abelian) group and some additonal axioms on $\cdot$.
Fundamentally a group has only one binary operation while a ring is a set equipped with two binary operations.
For example the set $\{-1, 1\}$ together with usual number multiplication is a group. Another example is a group of all permutations over a finite set $S_n$. On the other hand integers $\mathbb{Z}$ together with usual addition and multiplication is a ring. Note that this implies that $\mathbb{Z}$ is also a group if you look only at the addition.
Now a field is just a special ring: the one where every non-zero element is invertible (with respect to the second binary operation). For example $\mathbb{Z}$ is not a field, because $2$ has no multiplicative inverse (being $\frac{1}{2}$) but the set of rationals $\mathbb{Q}$ is a field. You can also think about fields as rings where division (by non-zero elements) is well defined.
To fully understand these definitions you need to read some sources. Wikipedia is a good place to start:
https://en.wikipedia.org/wiki/Group_(mathematics) https://en.wikipedia.org/wiki/Ring_(mathematics) https://en.wikipedia.org/wiki/Field_(mathematics)
