In other words, are there infinitely many numbers $n$ such that all numbers smaller than $n$ and relatively prime to it are primes ? For example, $ n = 30$ works.
Note that existence of such numbers would trivially imply the conjecture in this question as true.
katana_0
  • 1,862
It is not difficult to see that $\omega(n)\leq 2\log n$, while there exists a constant $A>0$ such that
$$\varphi(n)>A\frac{n}{\log\log n}$$
(see here). Hence,
$$\pi(n)=\varphi(n)-\omega(n)>A\frac{n}{\log\log n}-2\log n$$
but by the PNT $\pi(n)\sim n/\log n$, so for all large $n$, there is an $\epsilon>0$ such that
$$\frac{n}{\log n}-\epsilon<A\frac{n}{\log\log n}-2\log n \qquad\forall n\geq n_0\text{ satisfying the condition},$$
but this is not possible if you take $n$ large enough. Hence there are only finitely many solutions.
user246336
  • 3,579
If $n$ is not a multiple of 2 then it has to be less than $2^2$.
If $n$ is not a multiple of 3 then it has to be less than $3^2$.
If $n$ is not a multiple of 5 then it has to be less than $5^2$ etc.
This suggest that the only candidates for $n$ are the primorials. But the next primorial after $30$ is $2 \times 3 \times 5 \times 7 = 210$, and $210 > 11^2$, so that doesn't work. And neither will higher primorials.
gandalf61
  • 15,326
