i worked in cabinetry, and i tried a bunch of times to apply calculus to the roll of edge tape. the final diameter is the roll the tape is on, the beginning diameter is the roll plus the tape. the tape has a thickness. i would like to know the length of the tape and the rate of change of the diameter. i just went back to it and i'm still not quite sure. i have completed calc III and have still not touched this.
1Also see this question – Ross Millikan May 10 '18 at 04:39
Thickness tape is p
N is the number of turns.
Initial radius + p *n is the total radius
Each wind has the circumference pi*(r+p*n)^2 The sum from 1 to n of the above equation is your length.
- 2,390
true. but the rolls of tape i was using were 4' in diameter 1/10th of an inch thick, and were run by robots with a tolerance of 1/1000th of an inch. they also didn't have an inner roll that stepped it. even if they did you wouldn't see the step after a couple of passes. was expecting archemedian spiral in polar. – Hemofelicity May 10 '18 at 06:07
Each time the tape wraps around, how much does the radius, and therefore the circumference, increase?
- 107,799
While calculus is certainly an option for this question, I would like to point out that it's not necessary. Consider this: Your roll of tape has some volume. You can find this pretty easily with the volume formula for cylinders: $\pi hr^2$, or for this case $\pi wr^2$ where $w$ is the width of the tape. Now clearly, if you unwind the entire roll of tape, the volume won't change. So, we can also write down an expression for the volume of the tape when unwound: $wlt$ where $l$ is the lenght, and $t$ the thickness. Setting these equal to each other and solving: $$\begin{aligned} wlt&=\pi wr^2 \\ lt&=\pi r^2 \\ l&=\frac{\pi r^2}t \end{aligned}$$ we get an expression for the length of tape. No calculus needed.
- 1,195
