Let $X$ be a topological space and $Y$ a subset of $X$. Write $i: Y \to X$ for the inclusion map. Choose the correct statement:
  1. If $i$ is continuous, then $Y$ has the subspace topology.
  2. If $Y$ is an open subset of $X$, then $i(U)$ is open in $X$ for all subsets $U \subseteq Y$ that are open in the subspace topology on $Y$.
As-
  1. Since $i$ is continuous means $i^{-1}(V)$ is open in $Y$ for any open $V$ in $X$. So can we say first option is wrong as $Y$ can have any topology which is stronger than the subspace topology.
  2. Since $U$ is open in subspace topology which means there exist an open set $V \in X$ such that $U = V \cap Y$. Then $i(U) = i(V\cap Y) $
    How to think further?
PAMG
  • 4,440
  1. Yes, the first assertion is false, but you should provide an example. For instance, you can take $X=\mathbb R$ with the usual topology and $Y=[-1,1]$ with the discrete topology.
  2. $i(U)=U=V\cap Y$, which is open in $X$, since both $V$ and $Y$ are open in $X$.
I came across a map like: (X, T1) and (X, T2) is a topological space with topologies T1 and T2 where T1 is stronger than T2. Can we say that a map from (X, T1) to (X, T2) is an inclusion map? Anybody please.
