Strictly speaking this statement is not true. Fix a smooth function $\phi$ with compact support equal to $1$ on a neighborhood of zero and define
$$f(x)=\begin{cases} \phi(x) e^{-1/x^2} & x \neq 0 \\
0 & x=0 \end{cases}.$$
Then $u(f;R)=0$ for all $R$, but $f$ is not analytic on any neighborhood of zero.
This statement is sort of "morally true" however, in the sense that you should only expect $u(f;R)$ to make sense if $f$ is analytic on a disk centered at the origin of radius greater than $R$, even though there can be exceptions. To see this, consider now a smooth function $\phi$ with support compactly contained in $[-1,1]$ and which is equal to $1$ on a neighborhood of zero. Then look at $f(x)=\frac{\phi(x)}{x-1}$. For this, $u(f;R)$ diverges if $R \geq 1$, even though $f$ is clearly a $C^\infty_c$ function. What is the problem? The problem is that $f$ is a non-analytic continuation of the meromorphic function $\frac{1}{z-1}$ which has a pole at $z=1$. But $u$ only sees the behavior of $f$ on an infinitesimal neighborhood of $0$, so $u$ "thinks" that $f$ is actually that meromorphic function. This prohibits convergence of the series for $R \geq 1$.
In any case, the main point is that the topology on $D$ forces all distributions to have some finite "order", they cannot take derivatives above this order. This allows us to handle non-analytic smooth functions within the framework of distribution theory.
