I don't know if I understand correctly. The base situation is explained in the following image:
formula: $s$ = state, $a$ = action, $A$ = set of actions, $S$ = set of states, $s'$ = next state, $P_{ss'}^a$ matrix of probabilities.
$$V_{\pi}(s) = \sum_{a \in A}\pi(a|s)(R_{s}^a + y\sum_{s' \in S}P_{ss'}^aV_{\pi}(s'))$$
My problem is that when I calculate the $V_{\pi(s)}$ for the state that has the action Pub. Because for the $V_{\pi(s)}$ I need to calculate all $V_{\pi(s')}$ and one of the $s'$ is the current $s$, I enter a loop.
My question are:
When I start the calculation are all state values null or is there some type of initial value?
If there are initial values, how can I calculate them?
Is my interpretation correct? Is there a loop or not?
If there isn't, can you explain why?
Thanks in advance for your answers.
