I am looking for the proof that the following $n$th order ODE $$ y^{(n)}(t)+p_{n-1}(t)y^{(n-1)}(t)+\cdots+p_1(t)y'(t)+p_0(t)y(t)=g(t) $$ for $t\in (a,b)$ and $p_i$ and $g$ continuous on $(a,b)$ with $$ y(t_0)=y_0,y'(t_0)=y_0',\dots,y^{(n-1)}(t_0)=y_0^{(n-1)} $$ for some $t_0\in (a,b)$ has a unique solution on the entire interval $(a,b)$. This is as stated in Boyce and De Prima. However, a proof is not offered. Furthermore, I dug up the referenced text and couldn't find a proof there either (the edition was different, so it is possible I missed it). Hirsch Smale and Devaney just asserts a result for non explicitly $t$ dependent coefficients and then moves on to fully nonlinear equations and dynamics. I am hoping for a more nitty gritty proof. And for convenience, I would be fine with taking $n=2$ if it extrapolates nicely.
My ideas to proceed; we can certainly reduce this to a system of first order ode's (and I think it suffices to examine the homogeneous version by variation of parameters) and try and prove existence and uniqueness in the first order cases.
However, what troubles me is I don't see how to use Picard's theorem to get existence and uniqueness on the whole interval where all the $p_i$ are continuous. Wouldn't we need to restrict to a (sufficiently small) compact subset to make sure the integral operator we define is a contraction for the Banach fixed point theorem argument to go through?
I confess I haven't worked out all the details myself, so I apologize if I missed something obvious. I am also not that familiar with the Wronskian, and maybe that's where the solution will come from.
