17
Consider the collection $\mathcal{X}$ of
  • compact and connected subsets of $\mathbb{R}^2$,
  • that are the closure of some open subset of $\mathbb{R}^2$, and
  • have area $a$.
For any $\Omega \in \mathcal{X}$ and any $x,y \in \Omega$, let $d(x,y,\Omega)$ be the length of the shortest path lying entirely inside $\Omega$ and connecting $x$ to $y$.
Also, let $\mathbb{1}(x,y,\Omega)$ be the indicator function that equals $1$ if $x$ and $y$ are both in $\Omega$, and zero otherwise.
I am interested in the following problem:
$$\min_{\Omega \in \mathcal{X}} \int_{x\in \mathbb{R}^2}\int_{y\in \mathbb{R}^2} d(x,y,\Omega) \mathbb{1}(x,y,\Omega) dx dy$$
  1. Is there a well-known solution to this problem?
  2. Is it possible to show that a solution to this problem must be convex?
  3. Is the problem even well-defined (e.g., does $d(x,y,\Omega)$ always exist? I tried to help guaranteeing it by including only closed and connected sets in $\mathcal{X}$, but I am not 100% sure that's enough)?
  4. Is the problem guaranteed to have a solution without more regularity conditions?
Some related problems are described here: https://link.springer.com/article/10.1007/s10958-012-0717-3. Unfortunately, these related problems either (1) focus on "networks" rather than "thick" sets, (2) focus right away on convex sets, or (3) do not fix the area and instead impose an additional "cost" to the minimization problem for increasing the area.
    It seems to me that the extremizer will either be a disk, or that you can get arbitrarily close to zero (perhaps with long, thin rectangles?). –  Mar 16 '18 at 21:49
  • This is my intuition too, but I am having a hard time formalizing it. – Martin Van der Linden Mar 16 '18 at 21:50
  • Maybe you could adapt a proof of the isoperimetric inequality to show that it's a disk (and after thinking more, I do not think my comment about rectangles will work). My intuition is that the extremizer will have to be convex (otherwise your path sometimes goes "around" an obstacle), but the symmetrization argument that is frequently used in proving the isoperimetric inequality appears to not apply here. Certainly an interesting problem... –  Mar 16 '18 at 21:52
    Exact same intuition about convexity and obstacles, although I am again struggling to prove it (this whole problem seems a little --- if not way --- beyond my math skills). Thanks for the interest anyways. – Martin Van der Linden Mar 16 '18 at 21:54
  • I'm going to nitpick, but shouldn't it be $\min_{\mathcal X} \int_{y\in\mathbb R^2}\int_{x\in\mathbb R^2}$? – N.Bach Mar 16 '18 at 22:00
  • To show that an optimal solution must be convex, I would try showing that, given any such subset in $\mathcal{X}$, the closed convex hull, re-scaled appropriately so that the area remains constant, has lesser average distance. I haven't done the calculations, but I suspect that this would work. – Theo Bendit Mar 16 '18 at 22:05
  • What a fascinating problem. – Nathaniel Bubis Mar 16 '18 at 22:05
  • @N.Bach: If correcting errors is nitpicking, then you are nitpicking ;) You're totally right. I'll correct that. I guess I should really write $\int_{-\infty}^{+\infty} \int_{-\infty}^{+\infty} \int_{-\infty}^{+\infty} \int_{-\infty}^{+\infty} d\big((x_1,x_2),(y_1,y_2),\Omega\big) \mathbb{1}\big((x_1,x_2),(y_1,y_2),\Omega\big) dx_1 dx_2 dy_1 dy_2$. But that's very cumbersome. Hopefully the current formulation is clear enough. If not, let me know and I'll change it. – Martin Van der Linden Mar 16 '18 at 22:08
  • I think it is fine as it is. Regarding your 3rd question, I think $d(x,y,\Omega)$ always exists. $\mathbb R^2$ is locally path-connected, which implies that open connected sets are also path-connected. Then $\Omega$ is path-connected because its interior is. – N.Bach Mar 16 '18 at 22:22
  • If the set is very short and wide, flattening it to half the thinkness but twice the width multiplies the integral by about 2. So it seems the set would have to have roughly equal dimensions. The integral is also rotationally invariant. I would put my money on a disc. – Reinstate Monica Mar 19 '18 at 19:28
  • Also consider an "earth-moving" argument. Let $A$ be a non-disc shape and $D$ be the disc at the same center of mass and the same area. Moving a clump of $A \setminus D$ into $D \setminus A$ preserves area but should reduce the integral. So $A$ can't be optimal. – Reinstate Monica Mar 19 '18 at 19:30
I don't know if this is well known (I guess it is), but here is an argument showing that a disc is the unique minimizer. Since the minimizer will end up being convex, we can consider straight-line distances instead of distances within the set.
Given such a set $\Omega$ with centre of mass $(0,0),$ consider the set $\Omega^{\mathrm{new}}$ defined by
$$(x,y)\in\Omega^{\mathrm{new}} \iff |y|\leq\frac12 \int 1(x,y',\Omega)dy'.$$
So in each vertical line segment $\Omega_x=\{y\mid (x,y)\in\Omega\},$ we replace the set by a centred version. By Fubini's theorem, the areas of $\Omega^{\mathrm{new}}$ and $\Omega$ are equal. For a fixed pair of distinct $x$-coordinates $x,x'$ consider the effect on the distance between points on those lines,
$$w(\Omega_x,\Omega_{x'})=\int_{y\in \Omega_x} \int_{y'\in \Omega_{x'}} |(x,y)-(x',y')| dy dy'$$
I claim this decreases when replacing $\Omega$ by $\Omega^{\mathrm{new}},$ except in the case where $\Omega$ and $\Omega^{\mathrm{new}}$ are a.e. equal or one is a null set.
To see this, first consider replacing $\Omega_{x'}$ by the interval (not necessarily centred at zero) of the same length but of the form $\{y\mid \Phi(y)<c\},$ where $\Phi(y)=\int_{y'\in \Omega_{x'}} |(x,y)-(x',y')| dy'.$ Note $\Phi$ is strictly convex so this does indeed produce an interval. This operation does not increase $w(\Omega_x,\Omega_{x'}).$ We then do the same the other way round. Both slices are now intervals, and a vertical translation takes them to $\Omega^{\mathrm{new}}.$ Doing this a bit more carefully would show that the weight strictly decreases for sets that actually change.
This shows that a minimizer must have reflection symmetry through every line through its centre of mass, and must therefore be rotationally invariant, and a bit of thought shows it has to be a disk.
The existence of a minimizer can be shown by compactness. The set of measures $\mu$ of total measure $a,$ contained in some fixed large disk, subject to the additional restriction $\mu(S)\leq\lambda(S)$ (bounded by Lebesgue measure), is compact in the vague (weak-*) topology. (I'm using measures here, but you can use something like $L^2$ if that's more intuitive.) Any indicator function of a compact set with area $a$ can be put into such a space, then we can invoke compactness to pick a minimizer $\mu.$ I will now argue that the minimizer has to be a set. (Actually this isn't really needed for the above argument - you could just replace sets by functions everywhere.) The potential $\Phi_\mu(x)=\int_{x'\in\mathbb R^2} |x-x'|d\mu(x')$ is convex, and in particular continuous. If there were sets $S_1,S_2$ with $\max \Phi_\mu(S_1)<\min \Phi_\mu(S_2)$ and $\mu(S_1)<\lambda(S_1)$ then we could move some mass from $S_2$ to $S_1$ and get a smaller total potential, a contradiction. This means $\mu$ is actually uniform distribution on a set of the form $\{\Phi_\mu<c\}.$
It is possible to have a compact connected closed set that is regular (equal to the closure of its interior) and not path-connected. Just thicken the sine part of the topologist's sine curve, and stick two of them back to back (e.g. the closure of the set of $(x,y)$ with $0<|x|<1$ and $|y-\sin 1/x|<\tfrac 1 4$), then scale to get the area correct. So the integral may not be finite. You can modify this example to get path-connected but a diverging integral.
Dap
  • 25,286
Not a positive answer, but from here we find that the average distance of two random points in a $w \times h$ rectangle is:
$$ \frac1{15} \left( \frac{w^3}{h^2}+\frac{h^3}{w^2}+d \left( 3-\frac{w^2}{h^2}-\frac{h^2}{w^2} \right) +\frac52 \left( \frac{h^2}{w}\log\frac{w+d}{h}+\frac{w^2}{h}\log\frac{h+d}{w} \right) \right)\;, $$
where $d=\sqrt{w^2+h^2}$.
Now WLOG let $a = 1$, $w = x$ and $h = 1/x$. We get the formula:
$$ \frac1{15} \left( x^5+x^{-5}+d \left( 3-x^4-x^{-4} \right) +\frac52 \left( x^{-3}\log(x^2+xd)+x^3\log(x^{-2}+d/x) \right) \right)\;, $$
where $d=\sqrt{x^2+x^{-2}}$.
For $x > 0$ this has a minimum at $x = 1$, ruling out "long thin rectangles".
orlp
  • 10,508
This is by no means a full answer, but points out some structure. I assume that $\Omega$ is convex and regular enough.
Let us denote $$ F(\Omega) = \int_{x\in\Omega}\int_{y\in\Omega}|x-y|\,dy\,dx. $$ In the convex setting, you are minimizing $F$.
Let $\ell(x,v)$ denote the distance from $x\in\Omega$ to $\partial\Omega$ in the direction $v\in S^1$. We use the convention that if $x\in\partial\Omega$ and $v$ points inward, then $\ell(x,v)>0$. More analytically, we can define $\ell(x,v)=\sup\{t\geq0;x+tv\in\Omega\}$.
The inner integral defining $F(\Omega)$ can be written in polar coordinates. The radial integral is easy to compute, and we find $$ F(\Omega) = \frac13\int_{x\in\Omega}\int_{v\in S^1}\ell(x,v)^3\,dv\,dx. $$ This is an integral over the ring bundle $S\Omega=\Omega\times S^1$ (also called the sphere bundle — $S^1$ is just the 1D sphere). One can change integration from the sphere bundle an integral over all lines and the space of lines using the so-called Santaló formula (see e.g. proposition 8.2 in these lecture notes for a proof in $\mathbb R^2$). This leads to $$ F(\Omega) = \frac1{3} \int_{x\in\partial\Omega} \int_{v\in S^1} |\langle v,\nu_x\rangle| \int_0^{\ell(x,v)}\ell(x+tv,v)^3 \,dt\,dv\,dx. $$ Here $\nu_x$ is the unit normal at $x$. The innermost integral is again an explicit 1D integral, and we get $$ F(\Omega) = \frac1{12} \int_{x\in\partial\Omega} \int_{v\in S^1_{x,in}} |\langle v,\nu_x\rangle| \ell(x,v)^4 \,dv\,dx. $$ On the other hand, the area of $\Omega$ is $$ |\Omega| = \frac1{2\pi} \int_{x\in\partial\Omega} \int_{v\in S^1_{x,in}} |\langle v,\nu_x\rangle| \ell(x,v) \,dv\,dx. $$ See exercise 96 in the linked notes. Here $S^1_{x,in}$ is the set of $v\in S^1$ which point towards the interior of $\Omega$ from $x\in\partial\Omega$. If $\partial_{in}S\Omega$ denotes the inward pointing boundary of the sphere bundle (the whole boundary is $\partial S\Omega=\partial\Omega\times S^1$) and we denote by $\sigma$ the measure corresponding to $|\langle v,\nu_x\rangle|\,dv\,dx$, we have $$ F(\Omega) = \frac1{12} \int_{\partial_{in}S\Omega}\ell(x,v)^4\,d\sigma(x,v) $$ and $$ |\Omega| = \frac1{2\pi} \int_{\partial_{in}S\Omega}\ell(x,v)\,d\sigma(x,v). $$ This puts $F(\Omega)$ and $|\Omega|$ in a very similar neat form.
The suspected extremal case is a disc of some radius $R>0$. In this case $\ell(x,v)=2R|\langle v,\nu_x\rangle|$ when $v$ points inward. Therefore it might be convenient to use the measure $\tilde\sigma$ corresponding to $dv\,dx$ instead. Let us denote $u(x,v)=|\langle v,\nu_x\rangle|$ for brevity.
Let me denote the length of the perimeter by $P=|\partial\Omega|$ and the diameter of $\Omega$ by $D$. Denoting $L^p=L^p(\partial_{in}S\Omega,\tilde\sigma)$, we have (for any $\alpha\geq0$ and $p\geq1$) $$ \begin{split} F(\Omega)&=\frac1{12}\|\ell^4u\|_{L^1},\\ |\Omega|&=\frac1{2\pi}\|\ell u\|_{L^1},\\ P&=\frac1\pi\|1\|_{L^p},\\ D&=\|\ell u^\alpha\|_{L^\infty}. \end{split} $$ These with the isoperimetric inequality $4\pi A\leq P^2$ and the isodiametric inequality $4A\leq\pi D^2$ and Hölder's inequality give something to play with. To give anything sharp, one has to apply Hölder's inequality in a way that gives equality when $\ell$ is a constant multiple of $u$.
