I wonder where does this formula is coming from? It is for finding the distance between two parallel lines when we have their linear equation: First line is:$ax+by+c=0$ Second line is:$ax+by+c_1=0$ Their distance :$$\frac{|c-c_1|}{\sqrt{a^2+b^2}}$$
3Does this answer your question? Proving formula for distance between 2 parallel lines – Oct 27 '21 at 12:42
HINT
Calculate the distance of each line from the origin that is
$$d=\frac{|a\cdot0+b\cdot0+c|}{\sqrt{a^2+b^2}}=\frac{|c|}{\sqrt{a^2+b^2}}$$
than take
- $|d_1-d_2|$ for the line on the same side ($c$ and $c_1$ have same sign)
- $|d_1+d_2|$ for the line on diffent sides ($c$ and $c_1$ have different sign)
from which the given formula is obtained.
- 154,566
Actually I wanted to ask about for the formula you have just used for calculating distance of a point (origin in your case)from a line. Where does it come from? – Abbas Feb 28 '18 at 16:06
Ah ok, for that I've just given the link here https://en.wikipedia.org/wiki/Distance_from_a_point_to_a_line (click on "distance") whwre you can find the proof for the standard formula. Please don't hesiste to ask for any other clarification! – user Feb 28 '18 at 16:10
Anyway if your aim is that you should re-formulate the OP as "Distance between a point and a line" and not "Distance between two parallel lines by having linear equations". It should be more clear to understand what you are asking for. – user Feb 28 '18 at 16:13
Take also a look here for related topic with proof https://math.stackexchange.com/questions/85761/distance-between-a-point-and-a-line – user Feb 28 '18 at 16:23
Shouldn't this$|d_1-d_2|$ be $|d_1+d_2|$because once we have calculated distance from origin we would add them to have total distance from each other – Abbas Feb 28 '18 at 16:55
@Abbas Think to the case with $c=c_1$ in this case the distance is equal to 0 then we need to take $|c-c_1|$. Of course the $|d_1-d_2|$ must be interpreted according to the sign of $c$ and $c_1$ but the final formula is correct. – user Feb 28 '18 at 16:59
Then it should be $||c|-|c_1||$in numerator. Shouldn't be equal to $|c-c_1|$ – Abbas Feb 28 '18 at 17:16
If line are on the same side $||c|-|c_1||=|c-c_1|$ if are on different sides $||c|+|c_1||=|c-c_1|$. – user Feb 28 '18 at 17:21
@Abbas as you can see, in any case at the numerator we have $|c-c_1|=|c_1-c|$ thus the formula always works! – user Feb 28 '18 at 17:25
@Abbas What is the extra information? Try with some simple example to see how it works for example y+x=1 and y+x=3 or y+x=-2. – user Feb 28 '18 at 17:33
You are right. I tried and convinced myself(there was sth that I couldn't understand now I do.)thank you. – Abbas Feb 28 '18 at 17:38
Alternatively: the perpendicular line that passes through origin is: $bx-ay=0$. It crosses the two parallel lines at: $$\left(-\frac{ac}{a^2+b^2},-\frac{bc}{a^2+b^2}\right) \ \ \text{and} \ \ \left(-\frac{ac_1}{a^2+b^2},-\frac{bc_1}{a^2+b^2}\right).$$ The distance between these points is: $$d=\sqrt{\left(\frac{a(c-c_1)}{a^2+b^2}\right)^2+\left(\frac{b(c-c_1)}{a^2+b^2}\right)^2}=\frac{|c-c_1|}{\sqrt{a^2+b^2}}.$$
- 31,482
Consider $ax+by+c=0$, assume $a,b,c \not =0.$
$y=0$: $X-$intercept: $x=-c/a;$
$x=0:$ $Y-$intercept: $y =-c/b.$
$A(-c/a,0); B(0,-c/b);$ $O(0,0);$
form a right $\triangle ABO$ with
lengths of legs $|c/a|$ and $|c/b|.$
Lenght of hypotenuse : $\sqrt{(c/a)^2+(c/b)^2}.$
Height, $h$, on $AB$ is the desired distance to the origin:
Area of $\triangle ABO$ :
Area $= (1/2)|c/a||c/b| = (1/2)h\sqrt{(c/a)^2+(c/b)^2}.$
Solve for $h:$
$h= \dfrac{c^2}{|ab|}\dfrac {|ab|}{|c|\sqrt{(a^2+b^2)}}$.
$h =\dfrac{|c|}{a^2+b^2}$.
Left to do :
The above gives you the distance of one line from the origin, regardless of the sign of $c.$
Now you have 2 lines , with $c,c _1.$
Find the distance between them.
(Does gimusi's answer help?)
- 20,344
- 2
- 17
- 28
As an alternative suppose wlog that $b\neq 0$ then translate vertically with $by\to by-c_1$ and obtain
- $ax+by+c=0\to ax+by+c-c_1=0$
- $ax+by+c_1\to ax+by=0$
then the distance between the two lines is equal to the distance of the translated line $ax+by+c-c_1=0$ from the origin that is indeed the given expression.
- 154,566
