It is not hard to see (say from the perspective of covering spaces) that there are a finite number of subgroups of a fixed finite index $n$ in a finitely generated free group $F_n$. Given a closed oriented surface $F$, are there a finite number of subgroups of $\pi_1(F)$ of a given index? If so is there a formula for this number?
This is a special case of a harder question answered in https://math.stackexchange.com/questions/803930/references-for-a-standard-result-about-coverings-of-riemann-surfaces/811936#811936 – Moishe Kohan Feb 24 '18 at 17:22
More generally, if $G$ is any finitely generated group, then it has only finitely many subgroups of any given index. Indeed, if $H\subseteq G$ is a subgroup of index $n$, then it is the stabilizer of a point in an action of $G$ on a set with $n$ elements (namely, the cosets of $H$). But there are only finitely many such actions since $G$ is finitely generated, so there can only be finitely many such subgroups $H$.
I don't know how to count how many subgroups there are of a given index when $G=\pi_1(F)$.
- 330,363
Thank you for the response! This was very helpful. I wish I could accept two answers as you both answered a part of my question. – user101010 Mar 03 '18 at 00:57
@Eric Wofsey has already explained why the number of subgroups of a given index is finite in a finitely generated group, so I'll just attempt to reproduce the formula for counting them.
There is a kind of recursive formula, depending on the genus $g$ of $F$. This comes from Chapter 14 of the book "Subgroup Growth", by Lubotzky and Segal. who attribute the result to A.D. Mednykh.
Let $a_n$ denote the number of subgroups of index $n$ in $\pi_1(F)$. Then $$a_n = \frac{1}{(n-1)!}h_n - \sum_{k=1}^{n-1}\frac{1}{(n-k)!}h_{n-k}a_k,$$ where $h_n$ is the number of homomorphisms from $\pi_1(F)$ to the symmetric group $S_n$. (In fact, this much is independent of $g$, and holds for any group in place of $\pi_1(F)$.)
But, for surface groups $F$ of genus $g$ (either orientable or non-orientable), there is a formula for $h_n$ that relies on the representation theory of the symmetric group: $$h_n = (n!)^{2g-1}\sum_{\chi\in\operatorname{Irr}(S_n)}\chi(1)^{2-2g}.$$ Here, $\operatorname{Irr}(S_n)$ denotes the set of irreducible characters of the symmetric group $S_n$.
Assuming I didn't make any mistake in my code, here are expressions in $g$ for the first few values of $n$ (of course $a_1 =1$ for any $g$):
> a := proc(n,g)
> local k;
> h(n,g)/(n-1)! - add( h(n-k,g)*thisproc(k,g),k=1..n-1)
> end proc:
> h := proc( n, g )
> uses GroupTheory;
> (n!)^(2*g-1) * `+`( op( map( `$` @ op, CharacterDegrees( CharacterTable( Symm( n ) ) ) ) ^~ (2-2*g) ) )
> end proc:
> for i from 2 to 5 do print(simplify(a(i,g))) end:
g
4 - 1
g g
36 9 g
--- + ---- - 2 4 + 1
6 3
g g g g
576 144 64 36 g g g
---- + ---- + --- - --- - 9 - 16 + 3 4 - 1
72 36 8 2
g g g g g g g g
14400 900 23 576 400 25 144 7 64 36 5 9 g (2 + 2 g)
------ + ---- - ------- + ---- - ------- - ----- - --- + ---- + 3 16 - 2 + 1
1440 90 288 80 36 8 6 3
(Even the simplified expressions get a bit messy after that.)
Note that it is fairly easy to see directly why $a_2 = 4^g - 1$. Any subgroup of index $2$ is normal, so $a_2$ just counts the number of homomorphisms from $\pi_1(F)$ onto a cyclic group $C_2$ of order $2$. It is clear from the defining relation for $\pi_1(F)$ that sending any non-empty subset of the $2g$ generators to the nontrivial element of $C_2$ (and the others to $1$) gives rise to a (surjective) homomorphism, which yields the value $a_2 = 2^{2g} - 1 = 4^g - 1$.
- 9,272
