I am trying to prove this statement for all $ n \geq 1 $ using induction: $$ \left( 1 + \frac{1}{n} \right)^{n} \leq \sum_{k=0}^{n} \frac{1}{k!} < 3. $$
I said:
  • Base case $ n = 1 $: $$ \left( 1 + \frac{1}{1} \right)^{1} \leq \sum_{k=0}^{1} \frac{1}{k!} < 3, $$ which is okay.
  • Induction step: Suppose that $ \displaystyle \left( 1 + \frac{1}{n} \right)^{n} \leq \sum_{k=0}^{n} \frac{1}{k!} < 3 $ for a given $ n \in \mathbb{N} $.
    Transition from $ n \to n + 1 $: $$ \displaystyle \left( 1 + \frac{1}{n + 1} \right)^{n+1} = \left( 1 + \frac{1}{n + 1} \right)^{n} \left( 1 + \frac{1}{n + 1} \right) = \ldots \text{Help} \ldots < 3. $$
I need some guidance for proof-writing (-thinking) in orders.
Asaf Karagila
  • 393,674
doniyor
  • 3,700
For all $ n \in \mathbb{N} $, we have \begin{align} \left( 1 + \frac{1}{n} \right)^{n} &= \sum_{k=0}^{n} \binom{n}{k} \left( \frac{1}{n} \right)^{k} \quad (\text{By the Binomial Theorem.}) \\ &= \sum_{k=0}^{n} \frac{n!}{k!(n - k)!} \cdot \frac{1}{n^{k}} \quad (\text{By the definition of the binomial coefficient.}) \\ &= \sum_{k=0}^{n} \frac{1}{k!} \cdot \frac{n!}{(n - k)!} \cdot \frac{1}{n^{k}} \\ &= \sum_{k=0}^{n} \frac{1}{k!} \left( \prod_{i=n-k+1}^{n} i \right) \frac{1}{n^{k}} \quad (\text{By cancellation of terms.}) \\ &\leq \sum_{k=0}^{n} \frac{1}{k!} \left( \prod_{i=n-k+1}^{n} n \right) \frac{1}{n^{k}} \quad (\text{As $ i \leq n $ for all $ i \in \{ n - k + 1,\ldots,n \} $.}) \\ &= \sum_{k=0}^{n} \frac{1}{k!} \cdot n^{k} \cdot \frac{1}{n^{k}} \\ &= \sum_{k=0}^{n} \frac{1}{k!} \\ &\leq 1 + \sum_{k=0}^{n-1} \frac{1}{2^{k}} \quad (\text{By comparison of terms.}) \\ &< 1 + \sum_{k=0}^{\infty} \frac{1}{2^{k}} \\ &= 1 + 2 \quad (\text{Sum of a well-known convergent geometric series.}) \\ &= 3. \quad (\text{Voilà!}) \end{align}
Haskell Curry
  • 19,524
Hint: There is no real need for induction. Use the Binomial Theorem.
André Nicolas
  • 507,029
  • The binomial coefficient is $\frac{1}{k!}(n)(n-1)\cdots(n-k+1)$. When we multiply by $1/n^{n-k}$, we get $\frac{1}{k!}$ times a bunch of terms that are each $\le 1$. – André Nicolas Dec 24 '12 at 07:54
    @doniyor Proving any statement for all natural numbers will need to make use of induction (sometimes the induction will be hidden). In case of the proof Andre suggests, the induction is used to prove the binomial theorem in the first place and in the subsequent "algebraic manipulations" you perform. –  Dec 24 '12 at 07:55
    @Marvis: Certainly induction is involved in any expression that has $\dots$ (\dots) in it. It all depends on how formal we want the argument to be. – André Nicolas Dec 24 '12 at 07:57
Your induction hypothesis $(1+\frac{1}{n})^n\leq\sum_{k=0}^{n}\frac{1}{k!}\lt 3$ for a given $n$, not for all $n$.
In the induction step, since $1+\frac1{n+1}>0$, you can multiply both sides of the i.p. by $1+\frac1{n+1}$, to get $$\left(1+\frac{1}{n+1}\right)^{n+1}\leq\left(1+\frac{1}{n}\right)^{n}\left(1+\frac{1}{n+1}\right)\overset{\mbox{i.p.}}{\leq}\left(\sum_{k=0}^{n}\frac{1}{k!}\right)\left(1+\frac{1}{n}\right)=\sum_{k=0}^{n}\frac{1}{k!}+\frac1{n+1}\sum_{k=0}^{n}\frac{1}{k!}$$ Can you continue?
Dennis Gulko
  • 15,640
To show that $\displaystyle\sum_{k=0}^{k=n}\frac{1}{k!} \lt 3$
$\displaystyle\sum_{k=0}^{k=n}\frac{1}{k!}=\frac{1}{0!}+\frac{1}{1!}+\frac{1}{2!}+\frac{1}{3!}+\dots+\frac{1}{n!}$
$\displaystyle\sum_{k=0}^{k=n}\frac{1}{k!}=1+1+\frac{1}{2!}+\frac{1}{3!}+\dots +\frac{1}{n!}$
$\displaystyle\sum_{k=0}^{k=n}\frac{1}{k!}=1+1+\frac{1}{2}+\frac{1}{2}\left(\frac{1}{3}+\frac{1}{3*4}+\frac{1}{3*4*5}+\dots+\frac{1}{3*4*5*\dots*n}\right)$
$\displaystyle\sum_{k=0}^{k=n}\frac{1}{k!}\lt1+1+1$
HOLYBIBLETHE
  • 2,770
