The origin of my question is the formula for the error of a Taylor polynomial. e.g. if $P_n(x)$ is the $n$th order Taylor Polynomial of $f(x)$ centered at $c$ then
$f(x) - P_n(x) = \frac{f^{(n+1)}(\xi)}{(n+1)!}(x-c)^{n+1}. $
A natural assertion is that the error decreases as we increase $n$ since $(n+1)!$ get's larger and we divide by that. Ignoring that if $(x-c)$ is small that $(x-c)^{n+1}$ very small as well, can we be sure that the derivative of $f$ won't grow even faster? That is, I'd just like to consider
$\lim_{n\rightarrow \infty}\frac{f^{(n+1)}(\xi)}{(n+1)!} $
I tried some calculations with
$ f(x) = e^{e^x}$
It seems like certainly $f^{(n)} \ge (e^x)^ne^{e^x}$ so then if I look at, let's say the term from $n-1$ T.P. so we have $n$ rather than $n+1$ and holding $x$ fixed (also note that $x$ should be $\xi$ but $\xi$ was almost unreadably in $e^{e^\xi}$)
$\lim_{n\rightarrow \infty}\frac{ (e^x)^ne^{e^x}}{n!} $
Applying L'hopitals and using the Gamma function for derivatives of factorials (like this question Derivative of a factorial) it looks like
$\lim_{n\rightarrow \infty}\frac{ n(e^x)^{n-1}e^{e^x}}{(n-1)!C_1} $
where C is that constant $(-\gamma+H_n)$ like in the referenced question. So it seems like the numerator will win out as we keep taking derivatives.
Is this reasoning right? I'm partly concerned because my intuition would be that a T.P. should nicely approach a nice smooth $C^\infty$ function like $e^{e^x}$, but this seems like a counter example, though admittedly I am ignoring the $(x-c)^n$ factor.
