I have a question concerning the ML-estimation of the trials of a Binomial variable. The setting is the following:
I have a random variable $X\sim Bin(n,p)$ with $n\in\mathbb{N}$ unknown, $p\in (0,1)$ the known success probability and with density (w.r.t. to the counting measure) $p_n(x)=\binom{n}{x}p^x(1-p)^{n-x}=:L_x(n)$. The log-likehood function is therefore given by $$l_x(n)=\log L_x(N)=\log(n!)-\log(x!)-\log((n-x)!)+x\log(p)+(n-x)\log(1-p) .$$ Maximizing $l_x(n)$ w.r.t. to $n$ is equivalent to maximizing $\log(n!)-\log((n-x)!)+n\log(1-p)$ or $\frac{n!}{(n-x)!}(1-p)^n$.
My problem is that I don't know how to proceed from here. A person in this thread Maximum likelihood estimate of $N$ (trials) in Binomial suggested that a solution is given by $\hat{n}=X/p$. However, $X/p\notin \mathbb{N}$ for most $p$, so I suspect that this can't be the answer.
J.Kar
  • 128
Consider $\dfrac{{n+1 \choose x}p^x(1-p)^{n+1-x}}{{n \choose x}p^x(1-p)^{n-x}} = \dfrac{(n+1)}{(n+1-x)}(1-p)$ which is less than $1$ when $n > \dfrac{x}{p}-1$, and so choosing $n+1$ in such a case would not give you a maximum likelihood estimate
Thus, given $x$ and $p$, your maximum likelihood estimate of $n$ is $\bigg\lfloor\dfrac{x}{p}\bigg\rfloor$ (rounding down)
unless $\dfrac{x}{p}$ is an integer in which case there are two with equal likelihood: $\dfrac{x}{p}-1$ and $\dfrac{x}{p}$
Henry
  • 157,058
  • thx a lot, I got it now! – J.Kar Jan 30 '18 at 19:39
    I didn't get it at all. Why should I consider this division term? Why would I want to choose n+1 ? Why should I be rounding down and not up? – Maverick Meerkat Feb 10 '20 at 17:29
    @DavidRefaeli One way of finding whether one likelihood is greater than another is to divide one by the other and compare the result with $1$. The actual division shows that any choice over $\frac x p$ does not give a maximum and also that any choice below $\frac x p -1 $ also fails to give a maximum. That is why you round down – Henry Feb 10 '20 at 17:37
  • @Henry ok. Suppose I have 3 results of 4,5,6. And that p is 13/15. Rounding down will give me 17 if I take the total (from 17.3), or 5 if I take the average (from 5.7). Which is clearly wrong, as I have a result of 6, meaning that the minimal n is 6, or 18 for total. What am I missing? – Maverick Meerkat Feb 10 '20 at 19:52
    @DavidRefaeli In the original question there was a single sample. There is an implicit indicator function in that that for the likelihood to be non-zero you need $n \ge x$ but that is not a problem as $\lfloor\frac{x}{p}\rfloor \ge x$. In your example with three samples, the maximum likelihood estimator would be different both because you start with $\prod\limits_i \frac{{n+1 \choose x_i}p^{x_i}(1-p)^{n+1-x_i}}{{n \choose x_i}p^{x_i}(1-p)^{n-x_i}}=\frac{(n+1)^3}{\prod(n+1-x_i)}(1-p)^3$ and because the estimator should explicitly be at least $\max(x_i)$ – Henry Feb 10 '20 at 21:08
  • @Henry I think it's probably more the 2nd argument, as $\frac{(n+1)^3}{\prod (n+1-x_i)}(1-p)^3 < \frac{(n+1)^3}{(n+1-min(x_i))^3}(1-p)^3$ which is less than 1 . – Maverick Meerkat Feb 10 '20 at 23:28
