If you have five blue, five red and five black pens (which show the differences by the colors), in how many ways you can put the pens in a row where there is never same color next to each other?
I've made a solution but I'm not sure it's the correct answer. Here is my solution: $$3\binom{10}5=756$$ $$756756 - 756 = 756000$$
Parcly Taxel
  • 103,344
JaneDoe
  • 71
5 Answers5
Let $\mathsf{B}$, $\mathsf{R}$, and $\mathsf{K}$ denote a Blue, Red, and blacK pen respectively. Then you're looking for “words” over the alphabet $\{\mathsf{B}, \mathsf{R}, \mathsf{K}\}$ in which no two consecutive letters are the same.
These are called Smirnov words, and there's a really cool trick you can do here. Consider the following: given any arbitrary word over the alphabet $\{\mathsf{B}, \mathsf{R}, \mathsf{K}\}$, suppose you “collapse” every run of identical letters into a single occurrence of that letter. Then you get a Smirnov word (word in which no two consecutive letters are the same). In the other direction, suppose you start with a Smirnov word, and replace each letter with some (positive) number of repetitions of that letter. Then, by starting with the appropriate Smirnov word and making the appropriate replacements, you can get absolutely any word.
In terms of generating functions, let $W(x, y, z)$ be the generating function for (arbitrary) words over the alphabet $\{\mathsf{B}, \mathsf{R}, \mathsf{K}\}$, where $x, y, z$ “mark” the occurrences of $\mathsf{B}$, $\mathsf{R}$, $\mathsf{K}$ respectively. (That is, the coefficient of $x^{n_1}y^{n_2}z^{n_3}$ in $W(x, y, z)$ is the number of words with $n_1$ $\mathsf{B}$s, $n_2$ $\mathsf{R}$s, and $n_3$ $\mathsf{K}$s.) And let $S(x, y, z)$ denote the generating function for Smirnov words. Then, what the previous paragraph shows is that (using the fact that the generating function for repeating something a positive number of times looks like $x + x^2 + x^3 + \dots = x/(1-x)$): $$W(x, y, z) = S\left(\frac{x}{1-x}, \frac{y}{1-y}, \frac{z}{1-z}\right)$$ which can be inverted to give: $$S(x, y, z) = W\left(\frac{x}{1+x}, \frac{y}{1+y}, \frac{z}{1+z}\right)$$
Of course, we know from first principles that $$W(x, y, z) = \frac{1}{1 - (x + y + z)}$$ so this gives $$S(x, y, z) = \frac{1}{1 - \frac{x}{1+x} - \frac{y}{1+y} - \frac{z}{1+z}}$$ in which we want the coefficient of $x^5y^5z^5$. This we can find with a computer-algebra tool like WolframAlpha, giving the answer: $$7188$$
Note that the same generating function works if you want the answer for $n_1$ blue pens, $n_2$ red pens, and $n_3$ black pens, whatever the values of $(n_1, n_2, n_3)$.
I learned this trick from pages 204–205 of the wonderful book Analytic Combinatorics by Flajolet and Sedgewick (available online here and here). (I wrote about something related a while ago.)
ShreevatsaR
  • 41,374
    This is awesome! You can tell from my use of $\text{SEQ}$ in my answer that I've also had the pleasure of reading this book. I was in love with it, an approach to combinatorics that is very distinct from anything I'd seen before. – Fimpellizzeri Jan 31 '18 at 01:30
Here is an approach in terms of generating functions:
Write $x$ for a blue, $y$ for a red, and $z$ for a black pen. An admissible arrangement looks as follows: $$\underline{\quad}\ z\ \underline{\quad}\ z\ \underline{\quad}\ z\ \underline{\quad}\ z\ \underline{\quad}\ z\ \underline{\quad}\ ,$$ whereby the six slots have to filled in with ixes and ypsilons. A single slot can be filled with $$1\ ,\ x,\ y ,\ xy,\ yx,\ xyx,\ yxy,\ xyxy,\ yxyx,\ xyxyx,\ \ldots\ ,\tag{1}$$ whereby the empty filling $1$ is excluded in the four central slots. The sum of all the terms appearing in $(1)$ computes to $${(1+x)(1+y)\over1-xy},\quad{\rm resp.}\quad{x+y+2xy\over1-xy}\ ,$$ whereby the second expression results if $1$ is excluded. If we now compute $$p(x,y):=\left({(1+x)(1+y)\over1-xy}\right)^2\left({x+y+2xy\over1-xy}\right)^4$$ then we obtain a term $x^r y^s$ with coefficient $1$ for each arrangement of pens containing $r$ ixes, $s$ ypsilons, and exactly five zeds, no adjacent letters being equal. We need the coefficient of the term $x^5y^5$ in $p$. To this end we write $$p(x,y)=(1+x)^2(1+y)^2(x+y+2xy)^4\sum_{k=0}^3{5+k\choose k}(xy)^k\ +{\rm terms\ of\ degree}>10\ .$$ Mathematica computed for me the coefficient of $t^{10}$ of the function $$f(t)=p_*(t x,t y)$$ (the star reflects the truncation of the higher terms). The result was $$21 x^8 y^2 + 806 x^7 y^3 + 4315 x^6 y^4 + 7188 x^5 y^5 + 4315 x^4 y^6 + 806 x^3 y^7 + 21 x^2 y^8\ ,$$ giving $7188$ as answer to the original question.
  • Can you derive, or provide a specific lead to the derivation of this specific generating function? – Antoni Parellada Jan 30 '18 at 12:17
  • The bible on generating functions is Wilf's generatingfunctionology, available here: https://www.math.upenn.edu/~wilf/gfology2.pdf – Christian Blatter Jan 30 '18 at 14:28
  • Thank you. I have the concept of generating functions, and, serendipitously (or perhaps deterministically), I happened to download the pdf and start reading it while I was waiting for your answer. I realize that a full derivation would be outside the confines of what is already a long and excellent answer, but I was fishing for a lead of sorts... (+1, BTW). – Antoni Parellada Jan 30 '18 at 15:04
    @mathkoan I have posted an answer that tries to explain this approach in a more accessible manner. Generating functions are a fantastic tool in a combinatorist's arsenal! Credits to Blatter, of course – Fimpellizzeri Jan 30 '18 at 15:09
  • @mathkoan I have posted another answer that takes a different approach using generating functions, if you want to be convinced of the utility of generating functions. :-) – ShreevatsaR Jan 30 '18 at 18:58
This is a more basic explanation on how to build Blatter's generation function. Following the reasoning and convention in his answer, pretend the we have an unlimited supply of blue balls $($represented by $x)$ and of red balls $($represented by $y)$. A valid filling for one of the middle slots has one of the forms:
$\qquad(1)$: a (possibly empty) sequence of $xy$'s followed by an $x$. This result in terms like $x, xyx, xyxyx, \dots$
$\qquad(2)$: a (possibly empty) sequence of $xy$'s preceded by $y$. This result in terms like $y, yxy, yxyxy, \dots$
$\qquad(3)$: a (possibly empty) sequence of $xy$'s preceded by an $xy$. This result in terms like $xy, xyxy, xyxyxy, \dots$
$\qquad(4)$: a (possibly empty) sequence of $xy$'s followed by $x$ and preceded by $y$. This result in terms like $yx, yxyx, yxyxyx, \dots$
These $4$ cases cover all possibilities.
When building a generating function, terms representing a required choice $\big($like choosing what to fill a blank $\_$ with, or following $\text{SEQ}(xy)$ with an $x$ in case $(1)\big)$ are multiplied, while term representing mutually exclusive possibilities are added.
With this mind, for any symbol $z$ a (possibly empty) sequence of $z$'s is given (in terms of formal power series/generating functions) by
$$1+z+z^2+z^3+\dots = \frac1{1-z}.\tag{$**$}$$
Hence, the corresponding term for each possibility above is
\begin{array}{c|c} \text{Case}&\text{Term}\\ \hline 1&\frac{x}{1-xy}\\\hline 2&\frac{y}{1-xy}\\\hline 3&\frac{xy}{1-xy}\\\hline 4&\frac{yx}{1-xy}\\ \end{array}
Of course the terms for $(3)$ and $(4)$ are equal, but I wrote their numerators in different orders to highlight that they represent different objects: $xy*\text{SEQ}(xy)$ for $(3)$ and $y*\text{SEQ}(xy)*x$ for $(4)$.
It thus follows that the general term for a middle slot
$$\frac{x}{1-xy}+\frac{y}{1-xy}+\frac{xy}{1-xy}+\frac{yx}{1-xy}=\frac{x+y+2xy}{1-xy}, \tag{$\triangle$}$$
and since we must fill $4$ of those slots our generating function will feature $(\triangle)$ to the fourth power.
Now, the endpoint slots also admit one possibility that is unaccounted for, namely that it is empty $($represented by $x^0y^0=1)$. Like we said before, one way of doing this is simply adding $1$ to $(\triangle)$:
$$1+\frac{x+y+2xy}{1-xy}=\frac{1+x+y+xy}{1-xy}=\frac{(1+x)(1+y)}{1-xy}, \tag{$\square$}$$
Another possibility would have been to consider a modified version of case $(3)$ that accounts for the empty possibility:
$\qquad(3')$: a (possibly empty) sequence of $xy$'s. This result in terms like $1, xy, xyxy, xyxyxy, \dots$
You see, the requirement in $(3)$ for there to be a preceding $xy$ was included specifically to prevent an empty result, so removing it adds the term we were missing. Like we calculated in $(**)$, the term corresponding to case $(3')$ is hence $\frac1{1-xy}$.
Cases $(1)$, $(2)$ and $(4)$ still apply, so our final term for an endpoint slot is
$$\frac{x}{1-xy}+\frac{y}{1-xy}+\frac{1}{1-xy}+\frac{yx}{1-xy}=\frac{1+x+y+xy}{1-xy}=\frac{(1+x)(1+y)}{1-xy},$$
yielding the same answer as before, of course. Since we must fill $2$ endpoint slots, this will be squared in our final generating function.
This covers all slots we had to fill, and hence our generating function is
$$p(x,y)=\frac{\big((1+x)(1+y)\big)^2(x+y+2xy)^4}{(1-xy)^6}$$
Now we turn back to the start. We don't actually have an unlimited supply of blue or red balls -- we are only interested in the case of exactly $5$ blue balls and $5$ red bals. It suffices hence to extract the coefficient of $x^5y^5$ in the power series of $p$ about $(0,0)$.
Fimpellizzeri
  • 23,126
  • Fantastic pedagogic effort! Thank you! – Antoni Parellada Jan 30 '18 at 15:22
  • You're welcome! Glad to help. – Fimpellizzeri Jan 30 '18 at 15:41
  • Nice! As a sanity check, I posted an answer with another approach involving generating functions, using which we can derive the $(\triangle)$ and $(\square)$ above in a different way. We start with the generating function for all words over $x$ and $y$, namely $\frac{1}{1-(x+y)}$. Applying the trick from that answer, we get the generating function for words without a letter consecutively repeated as $\frac{1}{1-\frac{x}{1+x}-\frac{y}{1+y}} = \frac{(1+x)(1+y)}{1-xy}$. This gives us $\square$, and we can subtract $1$ from it to get $\triangle$, because we don't want the empty word in that case. – ShreevatsaR Jan 30 '18 at 23:55
    Thanks for your comment. I realized another way of deriving $\square$ and $\triangle$: a sequence of $x$ and $y$ with no repetition can be denoted by the regular expression y?(xy)*x?, i.e. an optional y followed by a sequence of xy, followed by an optional x. This gives $(1 + y) \frac{1}{1-xy} (1 + x)$, which is precisely $\square$, from which we can subtract $1$ to get $\triangle$. – ShreevatsaR Jan 31 '18 at 03:43
  • Quick after-thought... For complete accounting of possible arrangements, shouldn't there be also a scenario where the (possibly empty) sequence $xy$ was followed by $xy?$ It is equally tautological as option (3). I understand option (3) is the focus of tweaking down the line, but still... – Antoni Parellada Feb 01 '18 at 13:40
  • @ShreevatsaR That's much simpler! I like it. – Fimpellizzeri Feb 01 '18 at 15:10
    @mathkoan Either one or the other. In this case, 'preceded by $xy$' and 'followed by $xy$' result in the same words: nonempty sequences of $xy$'s. – Fimpellizzeri Feb 01 '18 at 15:10
OEIS sequence A110706 which gives a reference for the recurrence relation $$n(n+1)a_n=(n+1)(7n-4)a_{n-1}+8(n-2)^2a_{n-2}$$ It is easy to get $a_1=6,a_2=30$ and then we can easily get $a_3=174,a_4=1092,a_5=7188$. Note that the symmetry from permuting colours: $a_n$ is 6 times the number starting with blue, red.
almagest
  • 18,380
Another way, which can be used for even more complex situations, is the formula by Jair Taylor
Define a form of Laguerre polynomials for $k\geq 1$ by $q_k(x) = \sum_{i=1}^k \frac{(-1)^{i-k}}{i!} {k-1 \choose i-1}x^i$.
e.g. for $k=2, q_2(x)$ works out to ${(x^2-2x)}/2!$
The number of permutations will be given by
$$\int_0^\infty \prod_j q_{k_j}(x)\, e^{-x}\,dx.$$
The specific formula for this problem can be seen at Wolframalpha yielding the answer as $7188$
  • Thank you for pointing me to this. I have a question. Here, I see that using 5 blue, 5 red and 5 black pens, the exercise is to calculate the number of different ways to put the pens in a row where we never have same color pens next to each other. For my exercise, however, I am trying to calculate the number of possible arrangements of s1, ..., sn, where each si is an element of {A, B, C} and adjacent si's are not the same alphabet. My exercise don't have a fixed number of A's, B's or C's, unlike this question which has 5 blue, 5 red and 5 black. I am trying to understand the difference... – Shatarupa18 Sep 30 '23 at 00:10
  • For my exercise, I have : number of possible arrangements of s1, ..., sn where each si can be A, B or C, and adjacent si's are not the same alphabet = 3^n - number of arrangements where at least pair of adjacent si's are the same alphabet. I'd be grateful to be pointed to the direction or approach that I should take to try and work this out. Thank you so much. – Shatarupa18 Sep 30 '23 at 00:10
