Your answer is incorrect, since you cannot add ${\bf x}^T$ to $\bf{a}$. Instead, consider that:
$$({\bf A x})_{i} =\sum_j A_{ij} x_j $$
So that:
$${\bf x}^T{\bf A x} =\sum_{i}x_i\left(\sum_j A_{ij}x_j\right)$$
And:
$$\frac{\partial }{\partial x_k}\left({\bf x}^T{\bf A x}\right) =
\sum_{i\neq k}x_i\left(\sum_j A_{ij}x_j\right) + x_k\left(\sum_j A_{kj}x_j\right)
\right)
$$=\sum_{i\neq k}x_iA_{ik} + \sum_{i\neq k} A_{ki}x_i+2A_{kk} x_k=(({\bf A} + {\bf A^T}){\bf x})_{k}$$
Or:
$$\frac{\partial }{\partial x_k}\left({\bf x}^T{\bf A x}\right) =\left({\bf A} + {\bf A^T}\right){\bf x}$$
Thus your in your case, you should get:
$$\left({\bf M}^{-1} + {\bf M}^{-T}\right)({\bf x}-{\bf a})$$
Note that we could have equivalently decided to write this as:
$$({\bf x}-{\bf a})^T\left({\bf M}^{-1} + {\bf M}^{-T}\right)$$
Which one is correct? they both have the same values, but one is a column vector, and one is a row vector. One could define the derivative of a scalar by a vector as either a row or a column, and this choice is exactly the difference between "Numerator-layout notation" and "Denominator-layout notation". The choice is arbitrary - different authors choose differently, but it is important you choose consistently.
