Suppose $X_1,\ldots,X_n$ are a random sample of $U(-\theta,\theta)$ with $\theta>0$. How can find $$ E\left(|X_1|\ \big|\max |X_i| \right) $$ that $1\leq i\leq n$?
Elias Costa
  • 14,658
hadisanji
  • 999
  • https://math.stackexchange.com/questions/1007744/conditional-expectation-to-de-maximum-ex-1-mid-x-n, https://math.stackexchange.com/questions/617415/compute-ex-1y?noredirect=1&lq=1. – StubbornAtom Sep 18 '19 at 14:02
First, we simplify a little by defining $Y_i=|X_i|$, with $Y_i \sim U(0,\theta)$ and we get the equivalent problem of finding $E\left[Y_1| \max(Y_i)\right]$
Lets call $Z=\max(Y_i)$ and let $k$ be the index that attains the maximum ($Y_k = \max(Y_i)$). By the symmetry of the problem, $k$ is a discrete random variable, uniform in $1, 2 \cdots n$
Then
$$E[Y_1 | Z, k ] = \left\{ \begin{array}{ll} Z, & \hbox{if }k = 1, \\ Z/2, & \hbox{if }k\ne 1. \end{array} \right. $$
where the first is rather obvious, not so much the second: one should see (or prove) that conditioning on the event that the maximum value was $Z$ and that this was not attained by $Y_1$, only tells us, regarding $Y_1$, that its value is below $Z$; i.e. that the conditional density of $Y_1$ is uniform between $0$ and $Z$, and hence the expectation is $Z/2$.
But, by tower property, $$E[Y_1 | Z ] = E [E [Y_1 | Z,k]] = \frac{Z}{n} + \frac{Z}{2}\frac{n-1}{n}= \frac{Z}{2} \frac{n+1}{n}$$
leonbloy
  • 63,430
Idea: Find a $\sigma(\max |X_i|)$-measurable random variable $Y$ such that
$$\int_F |X_1| \, d\mathbb{P} = \int_F Y \, d\mathbb{P} \qquad (1)$$
for all $F:=[\max|X_i| \leq c]$, $c \in [0,\theta]$. Then $Y=\mathbb{E}(|X_1| \, |\max |X_i|)$ holds.
Let $c \in [0,\theta]$ We have
$$\int_F |X_1| \, d\mathbb{P} = \prod_{j=2}^n \underbrace{\int 1_{[0,c]}(|X_j|) \, d\mathbb{P}}_{=\frac{2c}{2\theta}} \cdot \underbrace{\int |X_1| \cdot 1_{[0,c]}(|X_1|) \, d\mathbb{P}}_{\frac{1}{2\theta} \int_{|x| \leq c} |x| \, dx = \frac{c^2}{2} \cdot \frac{1}{\theta}} = \frac{c^{n+1}}{\theta^n} \cdot \frac{1}{2} \qquad (2)$$
where we used $|X_j| \sim U(0,\theta)$ and the independence of the random variables. On the other hand we know that
$$\mathbb{P} \left[ \max |X_i| \leq c \right] = \prod_{j=1}^n \mathbb{P}[|X_j| \leq c] = \left( \frac{c}{\theta}\right)^n = \frac{n}{\theta^n} \cdot \int_0^c x^{n-1} \, dx \\ \Rightarrow \max |X_i| \sim \frac{n}{\theta^n} \cdot x^{n-1} \cdot 1_{[0,\theta]}(x) \, dx$$
Thus
$$\int_F \max(|X_i|) \, d\mathbb{P} = \int \max(|X_i|) \cdot 1_{[0,c]}(\max |X_i|) \, d\mathbb{P} \\ = \frac{n}{\theta^n} \int_{0}^c x \cdot x^{n-1} \, dx = \frac{n}{\theta^n} \cdot \frac{c^{n+1}}{n+1} \qquad (3)$$
If we compare (2) and (3) we see that
$$Y:= \frac{1}{2} \frac{n+1}{n} \cdot \max(|X_i|)$$
fulfills (1).
saz
  • 120,083
