$\newcommand{\id}{\text{id}}$ $\newcommand{\Hom}{\text{Hom}}$
Let $V$ be a $d$-dimensional real vector space, and let $2 \le k \le d-1$. Every inner product on $V$ induces an inner product on $\Lambda^k V$, in the following way
$$ \langle v_1 \wedge \dots \wedge v_k , w_1 \wedge \dots \wedge w_k \rangle:=\det (\langle v_i ,w_j \rangle). \tag{1}$$
Question:
What are necessary and sufficient conditions on an inner product on $\Lambda^k V$ to to be induced from a product on $V$ as in $(1)$?
(I restricted $k \neq 1,d$ because then of course, any metric is induced by a metric on the base).
I think there should be some "compatibility" or "symmetry" conditions, but I am not sure how to formulate them.
Edit:
If there exist an inducing product at the base, this product is unique. Perhaps we can construct an "inverse map" which is defined on all products on $\Lambda^k V$, and see when the result is an honest inner product on $V$.
Proof of uniqueness:
Suppose $g_1,g_2$ are inner products on $V$, which induce the same product on $\Lambda^k V$.
Let $A:(V,g_1) \to (V,g_2)$ be an isometry. Then the induced exterior map $$\bigwedge ^k A:(\Lambda^k V,\Lambda^k g_1) \to (\Lambda^k V,\Lambda^k g_2)$$
is an isometry, where $\Lambda^k g_i$ is the metric on $ \Lambda^k V$ induced by $g_i$ via $(1)$. Since by assumption $\Lambda^k g_1=\Lambda^k g_2$, we get that
$$\bigwedge ^k A:(\Lambda^k V,\Lambda^k g_1) \to (\Lambda^k V,\Lambda^k g_1)$$
is an isometry, i.e.
$$ \id_{\Lambda_k(V)}=(\bigwedge ^k A)^T \circ \bigwedge ^k A= \bigwedge ^k A^T \circ \bigwedge ^k A=\bigwedge ^k A^T A,$$
where the transpose in $A^T$ is taken with respect to the metric $g_1$. Denote $S=A^TA$. Then $S \in \Hom(V,V)$ is symmetric (w.r.t. $g_1$) and positive-definite, and satisfies $ \id_{\Lambda_k(V)} =\bigwedge^k S $.
This implies $S=\id_V$. (For a short proof, see this answer).
So, we have obtained $A^TA=\id_V$; Remembering the transpose was taken w.r.t $g_1$, this shows $A$ is an automorphism of $(V,g_1)$. Recalling that we assumed $A:(V,g_1) \to (V,g_2)$ was an isometry, this shows $g_1=g_2$.
