Let us agree to say that $\mu$ is a Radon measure on a metric space $X$ if it is a Borel measure which is finite on compact subsets and is such that:
- Every measurable subset $A$ is outer regular, meaning that $$\mu(A)=\inf\{\mu(V)\ |\ A\subset V,\ V\ \text{is open}\};$$
- Every open subset $U$ is inner regular, meaning that $$\mu(U)=\sup\{\mu(K)\ |\ K\subset U,\ K\ \text{is compact}\}.$$
The present question regards inner regularity. Indeed, as I read in Evans-Gariepy's Measure theory and fine properties of functions, Theorem 4, Chapter 1 (*), if $X=\mathbb{R}^n$ then every measurable subset is automatically inner regular. Is this a property of $\mathbb{R}^n$ alone? Formally:
Question. Which metric spaces have the property that for any Radon measure every measurable subset is inner regular?
(*) Notation and conventions in this book are a bit different from the ones of the present post.
EDIT. Specifically, in Evans-Gariepy's book a measure is a extended-real valued set function which is monotone and subadditive (usually, this is called a outer measure). A measurable set is one which satisfies Caratheodory's criterion: $$E\ \text{is measurable} \iff \forall T\subset X,\ \mu(T)=\mu(T\cap E)+ \mu(T\cap E^c).$$ A Radon measure is a (outer) measure which is:
- Borel regular, meaning that every Borel set is measurable and every set (even nonmeasurable ones) is contained in a Borel set of the same (outer) measure;
- Finite on compact subsets.
The aforementioned Theorem 4 of Chapter 1 says that, given a Radon (outer) measure on $\mathbb{R}^n$, every set (measurable or not) is outer regular and every measurable set is inner regular.
Remark 1. If $\mu$ is a Borel regular measure on $X$ such that every Borel set is inner regular, then every measurable subset of finite measure is inner regular. Indeed, if $M\subset X$ is measurable and has finite measure, then by applying two times the Borel regularity property we can get a Borel set $M'$ which is contained in $M$ and has the same measure as $M$.
Remark 2. In particular, if $X$ is locally compact and is expanding union of compact sets, as in Micheal's kind answer below, and if $\mu$ is a Borel regular Radon (outer) measure, I believe that every (Caratheodory) measurable subset is inner regular. Indeed let $M\subset X$ be measurable. If $\mu(M)<\infty$ we are done. If $\mu(M)=\infty$ then we can write it as an expanding union of sets of finite measure: $M=\cup_1^\infty M_j$. Every $M_j$ contains a compact $K_j$ such that $\mu(K_j)\ge \mu(M_j)-1$. Letting $j\to \infty$, $\mu(M_j)\to \mu(M)=\infty$ and so $\mu(K_j)\to \infty$ too. This proves the claim.
