I know from $rank(A)+nullity(A)=n$ that is $rank(A)=rank(A^T)=n$ and $nullity(A^T) ≠ 0$.Is there any other useful connection to solve this problem?
What is def(A)?? – Devendra Singh Rana Dec 27 '17 at 19:34
1Dimension of $N(A)$.My professor use that term to describe a dimension of nullspace. – VidaXpo Dec 27 '17 at 19:37
1@DevendraSinghRana "deficiency", aka nullity – Ben Grossmann Dec 27 '17 at 19:38
Rank A is n then it is not possible to have rank of AA^T to be m – Devendra Singh Rana Dec 27 '17 at 19:40
@DevendraSinghRana I corrected mistake. – VidaXpo Dec 27 '17 at 19:43
You have edited that looks fine now – Devendra Singh Rana Dec 27 '17 at 19:43
Suppose $A^TAv=0$; then also $v^TA^TAv=(Av)^T(Av)=0$, which implies $Av=0$. Since the null space of $A$ is trivial, you're done: $v=0$, so the nullity of $A^TA$ is zero and the rank is full.
Suppose $x=(x_1,\dots,x_n)\in\mathbb{R}^n$ and $x^Tx=0$; this means $$ x_1^2+x_2^2+\dots+x_n^2=0 $$ so $x_1=0, x_2=0,\dots,x_n=0$ and $x=0$. Apply it to $x=Av$.
- 238,574
$(Av)^T(Av)=0$, which implies $Av=0$ ; please explain this I didn't understand, sir! – Learning Dec 29 '17 at 10:20
Well ! Use the fact that $$RankA+RankB -k<=Rank (AB)<= min (Rank A , Rank B)$$ Where $A$ is $n×k$ and $B$ is $k×m$ matrix.
It will work surely!
- 1,780
- 1
- 15
- 32
1https://www.quora.com/How-do-I-show-rank-AB-≥rank-A-+rank-B-−n – Devendra Singh Rana Dec 27 '17 at 20:01
You can define:
$\mathbb{A}_{m\times n}(\mathbb{R})$ be the matrix of any linear transformation $T:\mathbb{R^n}\to\mathbb{R^m}$ .So by Sylvester's law $rank(A)+nullity(A)=n\implies rank(A)=n$
and we know that $rank(A)=rank(A^TA)$=$n$; [1]: Prove rank $A^TA$ = rank $A$ for any $A_{m \times n}$
here , $A^TA$ is $n\times n$ , has full rank.
Therefore , $A^TA$ is invertible. (Hope it may help you.)
- 1,301
