Let $a,b,c \in \mathbb{Z}, a,b \ne 0, d = (a,b)$. Then the equation $ax+by = c$ has an integer solution $x,y$ iff $d \mid c$. In that case there are infinitely many solutions.
Need to derive general solution using the parametric form.
The first issue concerns with "a" step in the proof, which is ubiquitously applied to derive the parametric form. This step is common in books, and MSE alike even though the answers at MSE are innovative sort of, as here.
I am repeating verbatim the contents of LeVeque's book titled: Fundamentals of Number Theory, pg. 39 and pg. 40, to show the context of the two issues.
By exploiting the connection we have established between the GCD of two integers and linear combinations of them, it is easy to analyze the linear Diophantine equation in two unknowns $x$ and $y$,
(6) $ax + by = c, \text{ s.t. } a,b,c,x,y \in \mathbb{Z}$
First suppose that $(a,b) = 1$. Then we know that for suitable $x,y \in \mathbb {Z}, ax + by = 1$, so $cx, cy$ give a solution of (6). If $x, y$ and $x_0, y_0$ are any two distinct solutions of (6), then
$a(x - x_0) + b(y - y_0) = c-c =0 \text{ <--------------Issue 1 }$.
Since $(a,b) =1$, the equation $\frac{a}{b} = -\frac{y-y_0}{x - x_0}$ shows that for some $t \in \mathbb {Z}$
(7) $y - y_0 = -at, \text{ } x - x_0 = bt$.
Contrariwise, if $x_0, y_0$ satisfy (6) and $t$ is an integer (including $0$), then the $x,y$ determined by (7) also satisfy (6). Hence, (7) provides a general solution of (6), in this case. As a passing remark to readers who have studied linear systems of algebraic or differential equations, we remark that a general solution of (6) has thus been given as the sum of a particular solution of the in-homogeneous equation and a general solution of the homogeneous equation, $ax + by = 0$.
Now suppose that in (6), $(a,b) = d$. If $d \nmid c$, there are obviously no solutions. If $d \mid c$, has exactly the same set of solutions as the simplified equation $\frac{a}{d}x + \frac{b}{d}y = \frac{c}{d}$, and since $(\frac{a}{d}, \frac{b}{d}) = 1$, we already know these. Hence we have the following theorem.
Theorem 2.9 A necessary and sufficient condition that the equation (6) have a solution $x,y$ is that $d \mid c$, where $d = (a,b)$. If there is one solution - say $x_0, y_0$ - there are infinitely many; they are exactly the numbers
(8) $x = x_0 + \frac{b}{d}t, y = y_0 -\frac{a}{d}t, t \in \mathbb {Z} \text{ <--------------Issue 2 }$
Issue 1 : Why the value of $c$ is assumed to be the same. For me, (6) can have unique solutions based on the values of $c$ that are a multiple of $d$. Hence $c$ is a particular value of the linear combination, that should not be repeated from one unique solution to another for given $a,b$.
Issue 2: I hope that the reason for (8) having change of sign in $x$ and $y$ terms is because of the needed cancellation of the terms containing $t$.
The same idea can be expressed as : There are infinitely many solutions given by the pairs :
(i) $x = x_0 \pm \dfrac{bt}{d}, y = y_0 \mp \dfrac{at}{d}$,
where $x_0, y_0$ is any particular solution, and $t$ is parameter.
I expect some reference(s) or enough detail for the latter issue.
– jiten Dec 12 '17 at 09:54The value for $t$ being derived as a fraction is completely unclear. Seems that the value of $t$ changes from $a$ to $b$.
